Old 01-09-2007, 12:45 AM
Trail Blazer Trail Blazer is offline
Cool 04' 300EC Ignition Problems ?
I just cant get my bike to idle at a slow speed for more than 15 seconds before it dies, using the stock EC fly wheel & ignition. I have a LT jet kit, FMF Gnary Pipe, FMF muffler.
Ec ignition: I measured the voltage going out from the ignition stator coil and got 6.5 volts at a low idle. 9 volts at a fast idle. The measurement was using the black/red and the black/white wires.
DE ignition: I measured the voltage going out from the ignition stator coil and got 12.5 volts at a low idle. 17.5 volts at a fast idle.
Reading other postings I found that the EC is a 100watt ignition and the DE is a 30 watt ignition. I suppose the EC ignition is used to power all those lights and not the ignition coil.
With the DE ignition and fly wheel the bike will idle at low speed and have a better pickup.
Is the bike under powered to spin the EC fly wheel or is the voltage to low ?
Can anyone verify the voltage on their bikes and post their results. Any comments would be appreciated.
_____________________
04' 300EC
98' KDX220R
83' XR200R
Old 01-10-2007, 11:49 AM
jeffd jeffd is offline
From what I have heard - some bikes idle and some don't... Not necessarily an ignition problem. How much time do you have on your bike? Have you checked the reeds?
My bike had the larger ignition and would idle for a bit without dying - I doubt it would idle for a long time without loading up...
Old 01-13-2007, 04:20 PM
Cool
I just had the top & bottom rebuilt.
Just to test the spark output, I held on to the plug and grounded it to the engine. The spark was weak compared to my 98' KDX220R. On my KDX I could not hang on to the plug without being jolted. I checked all wire connections for corrosion. Maybe I need a new ignition coil or a boost kit?
Maybe this is the problem people are having with jetting, it could be a weak spark. A weak spark would cause the bike to run on a smaller size jet, since a stronger spark would be needed to ignite a richer fuel mixture.
Old 01-13-2007, 05:05 PM
Brian VT Brian VT is offline
Could this weak spark be attributed to corrosion on the ignition due to the leaky plastic ignition cover ?
Old 01-13-2007, 09:23 PM
Some have had trouble with a weak spark due to lack of a good ground contact. Check the ground wire attachment to the frame. Clean off corrosion and reattach. I would use a little dielectric grease to keep the oxidation at bay.
Old 01-14-2007, 12:56 AM
Cool
I rechecked all my ground connections, they all in good condition.
Can someone verify there spark if its weak, just by hand cranking the kick starter with the spark plug out.
Old 01-14-2007, 07:54 AM
gasmonaut gasmonaut is offline
i have seen few of those burned iginition stators (ec and exc:s).
all tree had a similar problem on the stator coil .
the black coil was bubbled and they didn`t take full rpm:s on WOT.
I think you have the problem in the carb or the reeds.
04 ec300 --> 05 ec300 --> 06 ec300 -- 07 ec300
Old 01-14-2007, 06:56 PM
Cool
My DE ignition is brand spacking new. My Ec ignition shows no sign of damage.
The bike runs well at WOT but it seems like its not reaching full RPM. As though it has a RPM limiter on the bike.
The reeds and carb look good..
Thread Tools
Display Modes
MC65'06 ignition problems PYT Mini Gasser 's Corner 7 03-10-2009 01:40 AM
Efi/ignition gevandam General Discussions & Announcements 4 05-29-2007 05:31 PM
04 300EC Ignition changed to DE Ignition Trail Blazer Enduro Engine - 2 stroke 0 01-08-2007 01:48 AM
