jetting - idle issue.
with a 42 pilot my bike idles great, and idle screw works as it should. but i get a bog off the bottom. no adjustment of air screw will remove this bog.
with a 45 pilot and airscrew at 1.5, my bike has no bog on the bottom and runs much better/stronger off idle, BUT the idle screw has almost no effect when warm. i have to wind screw in and get it basically out of the idle circuit to keep it running. if i keep the idle screw in the same position for both pilots, it idles great w/42 but will stall w/45... any suggestions??? |
Raise the needle and run the 42. Off idle opens the throttle, which puts the carb on the needle. If you raise the needle, the transition is richer, to which the 45 pilot was pointing.
thanks, i'll give it a shot.
Good luck.
Sounds like good advice. What temp are you setting this for? I'm thinking of dropping to a 42 from a 45 myself.
2004 GasGas DE250 |
this was at 50 degrees, 1500ft ... it's too cold here now to jet (20 degrees..).. next warm day i'll test it out..
Well.....did the jetting tips work? Inquiring minds want to know.....Your jetting a 200 right?
Rick 99 EC 200 06 RM 250 AMA D36 375X OTHG 375S ***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals |
still too cold here to get an accurate reading. it should approach 40 degrees, so we shall see. yes the 200..
Thread Tools | |
Display Modes | |
2001 EC300 won't idle - can't get jetting right | bexi | Enduro Intake/Carburetion - 2 stroke | 16 | 03-04-2010 10:30 PM |
PWK replacement resolve idle, jetting issues? | socalscott | Enduro Engine - 2 stroke | 2 | 01-04-2010 12:32 PM |
clutch issue | boostedte37 | General Discussions & Announcements | 2 | 11-09-2009 06:58 PM |
ec 400 gearbox issue | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 09-05-2009 10:17 AM |
Internet Explorer 7 issue | MattR | Suggestion Box | 13 | 09-01-2007 04:05 AM |
