Old 04-23-2010, 09:48 AM
stainlesscycle's Avatar
Default cutting out at wot
rode today for 3 hours, was fine for first 2.5 hours..had to limp home after bike started to sputter/booowwaahh at wot - almost stalled up a big hill... i could let off the gas, and it would come back.. i first assumed it was almost outta fuel - i switched to reserve, and swapped the plug for the hell of it, and it didn't fix it..plug looked good, not lean... i got home, added 1.5 gallon fuel, and it still was doing it.. i checked flow from petcock, and it seemed fine...
another thing i noticed is: if i am wot and it's sputtering, i could pull the clutch in, and it would zip right back up. like if i took a load off the motor, it had no problems....
i haven't torn into it, but i'm assuming/hoping: main jet clogged or needle dirty. it could be a reed - but they're only 6 months old..i didn't do a buncha water crossings, and air filter is not terribly dirty...
any suggestions if it's not carb? this may be a moot point, as i'm gonna pull the carb now...hopefully that's all it is..
07 ec300
www.stainlesscycle.com
Old 04-23-2010, 12:06 PM
jostby jostby is offline
sounds like your sucking a piece of crud up into the main jet. Pulling the clutch in takes the load off of the engine. No load = less fuel needed.
I would rotate the carb and pull the bowl and jets to see if you can visibly see what's causing your problem. Before you rotate the carb and pull the bowl off put a clean paper towel underneath it and drain the bowl, see if anything comes out or if anything is in the bowl drain (main jet access plug) With any luck you will be able to see the piece of gunk that's giving you fits.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 04-23-2010, 02:42 PM
damaged carb boot. less than 6 months old. big tear in it. not good. i probably tore it replacing/removing the carb 3 times.....
carb was clean.
07 ec300
Old 04-23-2010, 03:23 PM
welp that wasn't it. switched to another carb boot.
i've set float height (16mm on pwk?), cleaned airfilter, changed spark plug*2, checked carb, checked reeds (i flipped them around to make sure they were sealing - they did not look perfect.....)
it is very hard to start, i can bump it, it'll run for a second and die..
i'm going in the electrical direction. maybe it was more of a loss of spark at wot. woohoo. at least i have a spare coil/cdi/stator.. i'll check kill switch first.
07 ec300
Old 04-27-2010, 12:35 AM
socalscott socalscott is offline
uh oh,
The Phantom strikes again. This issue has many victims and no one solution.
Some dude spent $1400, but the solution was that he took the silencer off and ran it down the road trying to blow it up. Something cleared out and it was fine. Hmm, or was it that a member fixed it and he didn't want the bike back.
Pfff, to many stories. I have one as well, but it doesn't matter. Yours will be unique in the end I'm sure.
Good luck
Old 04-27-2010, 04:57 AM
Silver Silver is offline
I had an 01 with a similar sounding issue.All though i would also foul plugs.Mine had a high speed miss/sputter.I went the carb route first.Finally settled on it was electrical.Actually tested my theory by taping a timing light to the bars if the timing light goes out while it is missing you have an electrical issue.Mine sorry to say was the CDI.But after changing it ran great.
Old 04-27-2010, 07:17 AM
i tore everything apart that had to do with carburetion and then switched to electrical. i cleaned eveything up, and tested stator. i could find no problems. it works now. i'm gonna do a few shakedown runs this week to see if the problem arises again. i didn't race last weekend, but i have races every weekend from now until november, so i hope it don't pop up during a race..
07 ec300
Old 05-23-2010, 01:36 PM
My 200MXC cut out on top and it turned out to be a coil on the stator.
It was elusive, as it ran fine on level ground. Once under load(grades) in the dirt she'd cut out. Plug got very wet.
Old 05-25-2010, 05:39 AM
Eric K Eric K is offline
I had similar symptoms which were due to a bad voltage regulator. At high RPM the voltage would drop - lights dim and the ignition would cut out causing it to sputter. You could check this out by checking voltage when it sputters.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Old 05-25-2010, 07:00 AM
no voltage regulator on mine. the problem has not resurfaced yet. hopefully going over the entire fuel and electrical system fixed it.
07 ec300
Thread Tools
Display Modes
FSE 450 cutting out jack1234 Enduro Engine 4 stroke (including EFI & Exhaust) 1 04-18-2008 11:20 AM
Safest/Easiest Way To Carry Trail Cutting Tools... tprnottp General Discussions & Announcements 1 01-01-2007 08:05 PM
cutting the mufler wmd Enduro Engine - 2 stroke 12 08-24-2006 02:14 PM
