Old 05-31-2010, 03:11 PM
nick790's Avatar
nick790 nick790 is offline
Default Sachs shock rebuild.
I currently have my shock stripped down to carry out the mod's to cure the known fault with lack of damping. I thought I'd take a look at the valving whilst it's apart. I was surprised how easy it comes apart and it seem very well engineered with no sings of wear, the only thing I could criticize are the rough flashing/burrs on the piston ports, I will smooth this out before it gets refitted.
I recorded the valving for you comment.
Rebound - all 12mm ID
18x.30
22x.20
26x.20
28x.25
30x.28
32x.25
34x.25
36x.25
38x.25
34x.20 & 34x.20ID 38x.20 OD.
38x.25
38x.25
PISTON
44x.20 (x4)
42x.20 (x2)
38x.10
36x.10
42x.20
40x.20
38x.20
36x.20
34x.20
32x.20
30x.20
28x.20
25x.25
22x.25
Comp all 12mm ID
I also measured the high speed adjuster shim stack
PISTON
10x.10
17x.10 (x6)
14x.10 (x2)
9x.20
I would like to reduce the high speed comp a little.
Anybody have any comments? What oil is best to use?
Thanks for looking
Old 05-31-2010, 09:52 PM
webmaster's Avatar
webmaster webmaster is online now
Administrator
Les is already giving him advice behind the scenes via me.... He doesn't give me valve spec info and he doesn't give it out over the internet either...
The shock oil to use is Spectro Very Light Shock Oil - I am not sure what equivalent is available in the U.K.
Sent you a PM with my valve spec guess...
Jeff
Webmaster
GasGas Riders Club
Thread Tools
Display Modes
ohlins shock rebuild... hannesd Enduro Suspension 12 12-27-2014 02:30 PM
Ohlins or sachs shock Gasgasogeros Enduro Suspension 2 07-29-2010 06:33 AM
07 EC250 Sachs shock WTEC Enduro Suspension 8 01-13-2010 12:07 PM
