Old 02-27-2007, 07:36 AM
lukachuki lukachuki is offline
Default Anyone else ever broken an air screw?
Hello All,
Longtime lurker,
Ever since I bought my '01 250 xco I have been unable to adjust my airscrew. It has always been turned all the way in and will not budge. Well after installing the LTR needle the other day I was determined to loosen up this seized screw. To no avail I broke off the head!!!
Any ideas on how to get it out and replaced?
Also the flexible air boot that the backside of the carbbie goes into needs to be replaced as the rubber is somewhat dried out and flaking. Anyone have this problem?
Thanks
Tim
Old 02-27-2007, 11:12 AM
kyle300 kyle300 is offline
You can drill the screw out, it is just soft brass. be careful not to damage the threads in the carb with the drill. The air boot sounds typical to an older bike. I find that using wd-40 keeps the rubber conditioned and more pliable over the years.
Old 02-27-2007, 01:10 PM
ok i'm going to sound like an idiot here but the "air screw" that I broke was plastic not brass. Any schematics of the carbby online?
Tim
Old 02-27-2007, 01:24 PM
jeffd jeffd is offline
Sudco is the u.s. importer for keihin; From their website:
http://www.sudco.com/Diagrams323728/exppwk.gif
Old 02-27-2007, 01:50 PM
eff's Avatar
eff eff is offline
I think he is refering to the idle adjuster screw. #29 on the attached image.
I think you would still have to go the drill route and then carefully run a tap through to clean out the threads.
Old 02-27-2007, 06:06 PM
yep the #29 idle adjustment. Anyone else had one seize up on them?
Old 02-28-2007, 09:06 PM
GMP's Avatar
GMP GMP is offline
No, but they get hard to turn and flex when the spring is near coil bind(close to full in). With the LTR jetting this will not be neccessary.
Old 03-04-2007, 11:21 AM
Gonzo's Avatar
Gonzo Gonzo is offline
Yeah, the useless plastic 'thing' on my carb's always been hard to adjust ever since i bought the bike. been wondering if they do a brass/steel replacement? or does it come with the ltr jet kit?
Gonzo is my name. GasGas is my game.
Old 03-04-2007, 04:31 PM
RBD RBD is offline
Gonzo,
The plastic idle screws have a sealant on the threads that make them hard to turn. I do sell the PWK plated steel idle screw.
Old 03-10-2007, 03:53 PM
Gonzo's Avatar
Brilliant! Just a shame you don't ship outside the US or I'd buy one this second.
And would have probably sent you my head by now.
Thread Tools
Display Modes
pilot jet vs. air screw question stainlesscycle Enduro Intake/Carburetion - 2 stroke 4 06-27-2010 02:51 PM
Help with air screw setting on RB-carb joey11 Enduro Intake/Carburetion - 2 stroke 7 02-17-2009 07:09 AM
clutch bleed screw Oldcow General Discussions & Announcements 2 07-19-2008 06:01 AM
Stripped screw in gas tank prk03 General Discussions & Announcements 2 06-18-2008 11:19 AM
200 with screw in the crank???? ramcclure200 Enduro Engine - 2 stroke 3 05-03-2007 11:42 PM
