Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
Proper way to flush engine oil?
Anybody know how to properly flush a 4-stroke Gasser engine oil? I was told to just get a few bottles of cheap 10w oil and pour them in to drain it out and replace/clean oil filter. Should I leave the oil stop bolts out or tighten them in, start engine and let idle for a minute, and then drain?
Thanks for help! Crankin04
04' GG FSE 450 Live Easy, Ride Hard! |
since nobody will take a try at this I will. If you're just trying to flush (old gunky oil) ATF is excellent for that purpose because it is a high detergent oil. In a car you might add 1qt before an oil change and drive it for 20 minutes before changing oil. In your case I would probably mix 50/50 and run it gently around the property until it warms up (10 minutes?) with no heavy loads and then immediately drain it.
The down-side is that high detergent oils can loosen up the small stuff that can clog up minuscule oil passages (like hydraulic lifters in the automotive world). I'm not sure if there is anything that could get damaged like that on a GG 4T, maybe a hydraulic timing chain tensioner? What's up that you feel you need to flush the engine case?
jeff '00 XC250 (mine) LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion. '04 EC250 (the kids) (he can do his own mods haha!) |
If you are flushing because of water contamination (drowned bike or sucked in water through breather) what i have been using for a while is to drain the milky oil, and replace it with paraffin, ride the bike up and down the road (gently) and drain out the paraffin then just add your normal oil and you good to go. If you a bit concerned about the little paraffin in the oil you can change the oil sooner than you would normally, but the dilution is so minimal there should be no difference.
Before i got told about this i used to try to flush out with cheap engine oil, but it would take about 3 attempts for the oil to stop being milky/grey Have also heard of using ATF and i know that there are loads of guys who swear by it instead of engine oil. It is also thinner so should flush out similar to the paraffin
Is there another term for "paraffin"? I am not familiar with that in the US except used to describe candle wax, I'm sure that is not the same thing. I have seen this term before and am curious.
Thanks!
I think it is kerosene in the US. basically the stuff you put in lanterns and hurricane lamps. It has similar properties to diesel, i suppose you could also use diesel.
Definitely not the wax! haha hope you have not been trying to stuff a litre of parrafin wax in your engine and cursing that crazy african!! You only ride the bike with it in for a minute or so, just to mix the water and kerosene up, and drain it before it separates again
OK, makes sense now. Thanks!
when drain the oil, tilt the moto to both sideways. You will find more oil to be drained.
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
What about proper flushing oil? Is it bad on bikes?
never heard of it, the water in the oil will disperse with heat into the fresh motor oil and thru the engine breather tubes, after one /two changes it will ok, you dont want to put anything other than engine oil in there because you cant get everything out, all engine oils mineral or syn are compatable with each other i doubt if other type of liquids are and the last thing you want to do is stuff up your clutch or bearing just to get excess moisture out your engine oil.
Thread Tools | |
Display Modes | |
Checking for proper power valve operation 2003 EC250 | SideshowBob | Enduro Engine - 2 stroke | 4 | 04-08-2010 01:00 PM |
Proper PV tension | PEB | Enduro Engine - 2 stroke | 7 | 10-08-2008 06:50 AM |
Gofasters.com Proper addition | 2 strokes 4 life | General Discussions & Announcements | 0 | 09-29-2008 10:48 PM |
Engine FAQ | webmaster | Enduro Engine - 2 stroke | 7 | 08-28-2006 06:39 AM |
