Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > Other GasGas Bikes/Quads
Other GasGas Bikes/Quads Trials, Pampera, Wild HP, etc.
Old 11-16-2010, 04:39 AM
2stroker 2stroker is offline
Default GG300 wild alternator
Hi,
How do we remove the alternator nut? Mine is a 30mm socket, and I dont know if it is rigth or left-hand thread. How do we block the crankshaft or flywheel, without damaging it?
I will be grateful for your help.
Old 11-16-2010, 09:14 AM
GMP's Avatar
GMP GMP is offline
If it uses the same crank as the bikes its a normal thread and spins off with an impact tool.
Old 11-16-2010, 09:42 AM
And how do you prevent the crankshaft to spin?
Old 11-16-2010, 11:46 AM
eff's Avatar
eff eff is offline
If you have the imact tool it will loosen it w/o it turning. They also make a flywheel holding tool or a piston blocking tool that keeps the motor from turning.
2004 GasGas DE250
Old 11-16-2010, 12:24 PM
jostby jostby is offline
A 1/2" drive air-powered impact wtrench will buzz it right off. You can hold the flywheel with your hand to keep it from spinning. A high-quality 3/8" drive impact will do it too.
If you don't have air tools handy take the spark plug out and feed about about 6" of 3/8" or 5/16" nylon rope onto the cylinder (leave the end hanging out so you don't lose it. It will lock up the engine when the piston comes up against it and shouldn't cause any damage.
It would be better to just load it up and pay someone at the local repair shop to buzz the nut off with air tools. Good luck.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 11-16-2010, 02:02 PM
It is impossible to hold the alternator flywheel with hands. The nut (30 mm socket) is so tight that it will not come off with the impact wrench, because it make the flywheel to spin together with the nut.
May I have to diassembly the clutch to hold the other crankshaft nut?
I never tried to lock the piston through the spark plug hole.
Old 11-17-2010, 09:08 AM
eff's Avatar
eff eff is offline
This tool is designed to hold the clutch ot your flywheel, $30.
http://www.motionpro.com/motorcycle/partno/08-0008/
Here is the engine lock up tool, $11.
http://www.rockymountainatvmc.com/pr...dFamilyId=6067
2004 GasGas DE250
Old 11-17-2010, 10:40 AM
I will try to lock the piston, since the rotor has a round shape.
thanks for help.
Thread Tools
Display Modes
please help hp wild 450 parts!!!! gasserwild Other GasGas Bikes/Quads 2 12-25-2019 10:44 AM
Raced My 2010 GG300 for the First Time Today 2whlrcr Off Road Racer's Corner 12 11-08-2010 09:08 AM
wild 300 and other 300's WILDGASGAS300 Enduro Engine - 2 stroke 1 10-26-2007 11:58 AM
MC65 has a working alternator bergerhag Enduro Electrical & Wiring 2 10-09-2007 05:34 AM
Wild 300 Hp PA300HPWILD Enduro Electrical & Wiring 0 10-09-2006 06:59 AM
