2011 Carb Size 36 or 38
Literature tells me the carbs are 38. However, the stamp on the top shows a 36 inside the little round cut out on the top of the slide cover. I have no clue if the two things are related. So are they 36 or 38's?
This is the 300 ec/xc. |
You have a 36 (same as mine). There is no logic to which bike gets what. You would think that 250s might have the 36 and 300s might have the 38, but that is not the case. Carb fitment is totally random.
2011 EC250E |
I thought the earlier bikes with the Sachs suspension (like mine) had 38mm carbs and the newer Ohlin/Zoke bikes had the 36mm.
My '11 250 has the 38 stamp.
Has anyone actually measured the carb bore to see if the "36/38" meant anything? |
Yes, I measured mine. It's stamped 36 on top and sure enough it was 36mm when I read the mic.
Mine is a Ohlins/Zoke '11 300 and it has the 38.... totally random I think.
2011 EC300 2013 TXT300 Factory Replica 2014 Polaris Assault 2004 Snowhawk 600H.O. |
Mines a 2011 ec300 Sixdays , 36mm carb. Zokes / Ohlins
I don't think anyone has found any logic to the carbs. My 11 EC300 has the 38 with Sachs stuff. It's perplexing.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250 |
Sachs/Ohlins 6 Days..38
2011 Six Days 250 |
11 300, Zokes / Ohlins 38
Thread Tools | |
Display Modes | |
Bib Mousse size? | gasgasman | Enduro Chassis & Body | 2 | 10-24-2008 05:08 PM |
Rim Lock Size? | Boomhauer | Enduro Chassis & Body | 4 | 09-17-2008 09:25 AM |
Nut Size | steve | Enduro Engine - 2 stroke | 2 | 01-11-2008 10:58 AM |
Carb Vent Tube Diameter/Size? | Captccb | General Discussions & Announcements | 1 | 11-05-2007 02:36 PM |
What size socket do i need | thelonius | General Discussions & Announcements | 2 | 10-03-2007 04:12 PM |
