XC250 2001 Crank shaft Interchange
Hello All,
I have a bad crank in a 2001 XC250 engine. What years will interchange? Is it correct that either a 250 or 300 cranks will work? Thank you, Tim |
250 and 300 are the same. The rod is from a CR250, typically $80 for the parts and $80 for labor to rebuild. I believe the rod is listed in the crossover section, I seem to remember that it's a 2000 model year/generation.
Phil (New bike pending...) |
Tim,
Cheapest to do the CR250 Rod kit as stated. The OEM rod is actually a Japanese Vesrah. Cranks should be the same over many years, but tolerances on the press fits have been an issue on some early bikes. I had a '00 with a loose fit I had the crank replaced under warranty, and a XC125 I had plasma sprayed and remachined. If your bearing fits are correct I would have the crank rebuilt. |
Thank you Phil and Glenn!
2001 XC250 Parting out | Slowgoin | Parts | 22 | 05-08-2013 01:31 AM |
2001 xc250 shifter shaft bent crossover for replacement | 70455 | Enduro Engine - 2 stroke | 4 | 11-23-2012 11:38 PM |
2001 xc250 crank nut won't budge | 70455 | Enduro Engine - 2 stroke | 10 | 11-15-2012 11:32 AM |
2001 GG TXT280 Part Interchange | GasGasDreamer | Other GasGas Bikes/Quads | 5 | 02-11-2011 03:08 PM |
2001 XC300 Crank shaft bearings | timlh | Enduro Engine - 2 stroke | 0 | 06-23-2010 06:23 PM |
