Old 08-03-2013, 09:35 AM
rosco's Avatar
rosco rosco is offline
What year 300 is it? We have been running a 172 main, 40 pilot, and a n3cj or cw on the 2nd clip at around 3500 to 5000 ft. with good results. The stock needle that comes in them just doesn't seem to work here. They really load up in the quarter throttle range.
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 08-03-2013, 09:45 AM
snailspacejase snailspacejase is offline
09. PWK carb. Running 178 main, 40 pilot and N1EF needle. 20 C and less than 1000 feet above sea level. The spring loaded pin on the float needle is compressed about 1/2mm when float seam is level with carb body. Clean air filter and exhaust. Very little slooge. Not too smokey at 50:1
Old 08-03-2013, 05:59 PM
bazzagas bazzagas is offline
Your local Yamaha/Suzuki/KTM dealer will sort you out with whichever needle you choose to go with. You may want to get a couple of different ones so you can compare them. I used an N8RH KTM needle simply because my local dealer had a spare one in his jetting box. It's still a tad rich but miles better than it was before. I could go a bit leaner with it but I'm happy enough at the minute so I will just leave it as is. There is a load of info on here and it takes a while to get your head round it all but stick with it and you will reap the benefits.
Old 08-04-2013, 03:24 PM
Jon250 Jon250 is offline
Thx for the response guys, my mate has now took it to a dyno were my ktm 250 was set up,which also uses the PWK carb, that had a power jet kit fitted to it, and it transformed the bike, it's a rocket now. Hope he can sort the gasgas out, I think the same will be done, as it is a similar issue to mine.
Old 08-05-2013, 02:02 PM
Ah the luxury of a dyno. Hope that sorts it.
Using the bung and tube method I have found my fuel level to be 1mm above the body/bowl seam. Could I take this lower, say to 2mm below? On some slow, steep descents I've noticed the idle drops and the motor stalls easily with extra smoke. I'm assuming the forward tilt of the carb combined with the downward angle of the bike is raising the fuel pressure in the carb. I'm using the bike for fairly gentle trail riding so not much WOT. Safe to go that low?
Old 08-15-2013, 02:23 PM
Ok. So I changed the needle to a NEDJ in clip 2. It has not cured the problem but I'm going to drop the main down to 172 next and see how that goes. Bike runs nice and smooth now with no burble/4 stroking at part throttle. However it is running hotter and pinks when you roll on and off small throttle openings. Also a marked reduction in bottom end torque. I'm going to raise the needle 1 clip and take it from there.
Old 08-15-2013, 04:17 PM
What sized pilot. Expect to use a 42 with the J diameter, and yeah go a clip richer. If thats too rich NECJ#3 will put you half way between the two.
The float heights are stock at 6.5mm but if you lower the fuel level another 1-2mm it will work much better.
Old 08-16-2013, 03:13 PM
PJ=40. Fuel level 2mm below bowl seam using bung and tube. I was hoping you would partake Jakobi.
The advice on here is excellent, and I'm enjoying the learning curve. Thanks guys.
I raised the needle a clip and I'm sure I've got back some bottom end grunt. It's very good and smooth, still a bit of pinking around very small throttle openings though. Need to change that pilot up from 40 to 42.
Old 08-19-2013, 06:00 AM
Changed to a 42pj and 172 main. I'm completely happy with the performance off road now (low to medium revs), lovely. The original problem is still there. Won't pull through a mid range flat spot with WOT but can be nursed through by closing to half throttle. When on the pipe she's away and pulls hard. These symptoms are aggravated by a period of slow riding and improve with a road blast. I wonder about leaning the main a bit more.
Old 08-19-2013, 11:41 AM
Jiikoo811 Jiikoo811 is offline
Have you check reeds allready?
Sent from Razr MAXX
plated 300EC 2008
Ec250 running issues jimgsxr86 Enduro Engine - 2 stroke 9 05-03-2013 05:52 PM
06-300 not running davedunaway Enduro Electrical & Wiring 11 08-29-2012 09:21 AM
03 300 not running tophat General Discussions & Announcements 22 08-23-2011 03:51 AM
Running hot Brian VT Enduro Engine - 2 stroke 9 10-01-2008 07:25 AM
Running In Dingo Enduro Engine - 2 stroke 3 07-26-2007 11:36 PM
