Old 08-14-2013, 10:04 PM
AZRickD AZRickD is offline
Default The RickyD Lectron Experience
Let the futzing begin...
Old 08-14-2013, 11:43 PM
Whats the verdict?
Old 08-14-2013, 11:57 PM
I had some mountain bike repairs to do and V-ball practice so I finally got to it an hour ago.
The first problem is the "long" Motion Pro throttle cable. It is 4.5 inches shorter than my stock GG cable. Also, the GG cable has that nice curve at the carb junction whereas the Motion Pro is straight.
Old 08-14-2013, 11:58 PM
Here is the condemning evidence...
Stock Gasser throttle cable is about 42.5 inches (when including the curve around the elbow).
The new Motion Pro cable is about 37 inches.
Old 08-15-2013, 01:18 AM
Anders Anders is offline
yep, I had the same experience. When I installed mine, I ended up using my spare Venhill cable wich is a tad longer than my OEM.
To be able to use the Keihin type cable, I made a new adjuster for the Domino throttle. My new adjuster lets the cable end go deep into the throttle housing instead of ending up outside the housing.
This is nescessary as the Lectron has a longer reach from the top of the carb to the slide. The other option is, as has been discussed here previously, to cut off some of the outer shielding of the cable. I feel that my solution is a better one, as I can continue using stock cables and don't need to modify a cable every time I need a new one.
Old 08-15-2013, 01:48 AM
Just for giggles, I hooked the Lectron up to the Gasser's stock cable and throttle assembly.
Once the throttle pulley was screwed in, the slide was half way up.
I don't feel like hacking up the GG cable.
What is the proper length (and model number) for the Motion Pro cable I need?
Old 08-15-2013, 02:16 AM
It's just past midnight here in Phoenix...
I installed the Lectron on the bike. Nobody told me I would have to tilt the shock back to make room for the beast.
Anyway, I left the GG cable in the carb routed as normal behind the number plate. Of course, it reaches, but with not enough slack. Note the elbow that just barely clears the tank.
The *only* way the Motion Pro cable would work is if I routed it KTM-style, on the rider-side of the bars and tucked in underneath the shroud. Maybe I'll buy one of those KTM throttle cable holder thingies. I don't know how the straight cable will function stuffed betwixt the carb and tank. Kinkage?
Okay. So, now what.... (?)
Old 08-15-2013, 03:23 AM
I thought I just told you what to do?
Just grab the lathe and make a new adjuster...
Old 08-15-2013, 03:32 AM
singletracker singletracker is offline
You guys need to call Kevin about the cable because mine came with a bend and fit perfect. They must have sent you the wrong one.
2011 250xc Race
Old 08-15-2013, 03:42 AM
Yes, you are right. But since I am living at the other side of the pond (Norway), shipping cables back and forth is just too slow and expensive to be worth while. Hence I solved it locally.
The Lectron - Review (vs SmartCarb) Jakobi Enduro Intake/Carburetion - 2 stroke 234 01-28-2014 08:13 AM
Smart Carb vs Lectron vs RB-Designs Mod AZRickD Enduro Intake/Carburetion - 2 stroke 49 08-09-2013 12:18 AM
Lectron Carb singletracker Enduro Product Reviews 145 07-27-2013 12:20 AM
Lectron Carburetor Testing & Adjustment singletracker Pictures & Videos 4 01-12-2013 09:37 AM
Lectron Binni Enduro Intake/Carburetion - 2 stroke 16 03-29-2011 09:44 PM
