No Spark
Just finished my transformation and have gone to start her up but dont have any spark
Bike was running fine so it would be somthing ive done, Have double checked all conections and earths new plug, seem to have power at the yellow wire from the stator, where to from here?
06 EC250 |
So I have tested the resistance of the stator following this
my reading were 104.6 17.6 0.5 0.3 TEMP was higher than 20 deg c so will re take later when its cooler re test approx 25 deg c was 102.5 17.3 0.5 0.3 with the readings i have would that cause it to have no spark? or could it still be a bad earth loose conection etc any help would be great thanks
06 EC250 Last edited by fullthrottle; 12-31-2013 at 07:31 AM. |
Hey mate, the readings you have are in the ball park according to the expected resistance .
1) Have you taken the spark plug off and earthed it out to the frame to check if you have any spark? 2) Have you confirmed your coil connections are ok? What exactly did you do with your transformation?. |
2 - have checked all conections on coil and disconnected kill switch 3 - with the transformation I removed subframe etc but mostly left wiring alone how would i know if there is an earth problem have checked earth on top triple clamp and have 3 earthson coil mount where they have always been regulator, coil, and the black wire that comes with the yellow regulator in wire. Checked both ends of the spark plug lead, the 3 connections near the top shock mount (not sure what they are lighting mabye.) unless there is a broken wire somewere or cdi problem im not sure but it was running fine before i started messing with it Dont know what to do next any ideas?
06 EC250 |
Not to poke fun...Did you try a different plug?
All healed up, and ready to burn some fat. |
Take another look at the wiring from the stator. Specifically the wires from the ignition pickup and the ignition source winding on the stator (larger winding that is different than the others).
Any unwanted grounding will prevent spark creation. Also check that your coil is securely mounted to the frame.
2011 EC250E |
Thanks for the replies
yep tried a brand new plug plus the one that was in it before
06 EC250 |
06 EC250 |
GOOD NEWS WE HAVE SPARK the white and blue wire going to the coil must have had a bad connection after Neil's post I went back to check that the coil was earthed properly once i removed the coil noticed that connection was loose. Thanks for the replies
06 EC250 |
Congrats! I hate chasing electrical gremlins.
99 no spark | c-152 | Enduro Electrical & Wiring | 10 | 06-30-2011 10:23 AM |
CDI? No spark | tommymoto | Enduro Electrical & Wiring | 4 | 02-28-2011 01:22 PM |
No Spark.. (i think) | Todd5774 | Enduro Electrical & Wiring | 22 | 01-21-2011 09:43 AM |
Fix for no spark | brains | Enduro Electrical & Wiring | 2 | 08-14-2010 12:38 AM |
no spark... | stainlesscycle | Enduro Electrical & Wiring | 9 | 02-17-2010 07:06 PM |
