#11
I have no info on the newer bikes, but if the key switch is the same as used on the 2011 estart bike, this is how it works:
KEY OFF - yellow/black is connected to yellow/green (grounds the ignition) KEY ON - red/black is connected to red (allows the start circuit to function)
2011 EC250E |
#13
The 4 wire connector on the wire harness for the ignition switch is a common connector. You should be able to pick one up from a local bike shop. If they don't sell it over the counter they should have a wiring kit in the service dept. If you can get one of these connectors you should be able to wire in your own switches without mutilating the wire harness.
#15
So i removed the key. Wired up a kill switch using 2 wires, yellow/green and black/yellow. Works great. Then i got a 3 post rocker switch from Napa. Wired the remaining 2 wires, red and red/black to power and load, then grounded to the triple clamp so i have a light lit when in on position. The cool thing is, i dont need the switch to be on to kick start, in turn the tail light remains off. Turn the switch on and i get a tail light and power to my starter. The switch also snapped into the bracket the key was in. A little loose so I super glued it so it doesn't vibrate. Last edited by scratch250; 01-19-2014 at 04:02 PM. |
Questions and help please? | darrenrd | General Discussions & Announcements | 4 | 08-01-2011 11:24 PM |
AC and DC Questions | speedy08 | Enduro Electrical & Wiring | 2 | 05-07-2011 10:34 AM |
Gas Gas MC 125 questions | MDN91 | Enduro Chassis & Body | 4 | 08-31-2008 05:54 AM |
GG FSR 515 Questions....what to do | pbspecial | General Discussions & Announcements | 9 | 04-14-2008 09:11 PM |
Questions About The 07's | Boomhauer | General Discussions & Announcements | 4 | 04-07-2007 12:17 PM |
