Old 01-26-2014, 06:53 AM
Preszo Preszo is offline
Default Rear Axle
Some advice please, I have removed the bearings from the rear wheel because the wheel had some play in it. I cleaned the axle with a wire brush to remove some dirt and rush/old grease and found wear makes where the bearing are located on the axle, it's like a very small grove worn into the axle the width of the bearings. Btw the old bearing where fine however these will be replaced.
Question do I need a new axle?
Thank in advance EC 250 2008
Old 01-26-2014, 12:41 PM
john r b's Avatar
john r b john r b is offline
Clean it up on a wire wheel.You should be good to go.
Old 01-27-2014, 11:10 AM
Thanks for the advice
Rear Wheel Axle singletracker Enduro Chassis & Body 38 07-24-2013 09:08 PM
rear axle Q nokturnal Enduro Chassis & Body 4 06-13-2012 10:52 PM
txt 250 1999 rear axle Rabbitist General Discussions & Announcements 0 03-15-2012 03:27 PM
Extended Rear Axle -450 Wild HP Beardy Other GasGas Bikes/Quads 3 07-01-2009 07:43 PM
rear axle nut skid jackson Enduro Chassis & Body 2 06-17-2007 06:52 PM
