Old 02-22-2014, 07:35 AM
canadianstrom canadianstrom is offline
Default VForce 3 reed wear
I pulled my reed valves to check them on my 11 EC300 - 60 hours ( trail ride speed mostly) . They all look good except the lower reed I could see a lot of light through the petal itself ( not the edges sealing to the frame ) when I held a flash light to it. It felt fine. Its surfaces felt the same and still seemed as stiff as the others. Is this an issue?
Thanks for any input.
Old 02-23-2014, 01:13 PM
Rick's Avatar
Rick Rick is offline
Are they closing completely? Meaning sealing on all 3 sides? No chipped or frayed edges?
They are pretty thin and carbon so it would seem to make sense that a bright lite would some what shine through them.
I'd say there fine as long as no chips on the edges.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 02-23-2014, 01:45 PM
Elvis74 Elvis74 is offline
I had the Problem with the vforce that they are sealed in the front but not on the sides also with new reeds. I switched back to boyesen reed cage and now the bike is working good.
Old 02-23-2014, 05:29 PM
Default thanks for ithe nput
The reeds do seal along the edges nicely. They all seemed to have a good seal and snap back in place. The only concern was one petal allowed light through.
Old 02-24-2014, 01:31 AM
If light comes through, it is not sealed!!!
Old 02-24-2014, 05:57 AM
Default light
ok to be clear, the light is NOT coming through were the reed petal contacts the frame. is through the entire petal. Like the carbon fibre weave is more widley spaced.
Old 02-24-2014, 10:21 AM
Should be no problem, as long the petal is not broken
vforce replacement reed part number? stainlesscycle Enduro Intake/Carburetion - 2 stroke 0 10-24-2012 04:45 AM
More oil = less wear Eric K Enduro Engine - 2 stroke 16 01-31-2010 05:49 AM
Replacement Vforce reed petals? Part # joey11 Enduro Intake/Carburetion - 2 stroke 1 02-10-2009 05:28 PM
Vforce for 200ec RayGas Enduro Intake/Carburetion - 2 stroke 1 01-14-2008 04:03 PM
