Old 03-24-2014, 03:52 PM
Do you know where they ended up with the jetting? I had a little play with mine again yesterday and decided to switch to the Suzuki needles for the next round of testing. I still need to do some plug chops as well to establish whats going on with the main, but the weather hasn't been conductive to testing. I was thinking about taking the time to check the reeds just to be sure as well, and have all intention of double checking the PV setup as soon as I find a reason to remove the pipe.
Old 04-02-2014, 04:22 AM
rubber Jonny rubber Jonny is offline
Jakobi - what are you checking in the power valve? That its clean or something else?
Old 04-02-2014, 04:43 AM
Making sure there is a little preload on the flapper from the governor/actuating arm. Sometimes they get a little slop and don't hold the PV flapper down completely at low rpm.
I'll probably check the spring and number of shims in the governor as well.
Engine won't run at high revs motopsycho87 Enduro Engine - 2 stroke 36 08-28-2013 04:37 PM
Peddle Driven desertgasser300 General Discussions & Announcements 14 04-29-2013 11:57 PM
New 2010 EC300 Engine Noise (falling revs) Jakobi Enduro Engine - 2 stroke 11 11-16-2010 06:41 PM
Max revs when starting up. Todd5774 Enduro Intake/Carburetion - 2 stroke 4 01-24-2010 08:22 AM
L@@king for a 200 Primary Driven Gear set Berkyboy General Discussions & Announcements 2 03-10-2007 09:07 AM
