Old 05-03-2014, 01:46 PM
john r b's Avatar
john r b john r b is offline
That is the correct cable. Maybe have a look at the throttle valve and spring connection? This cable fit like a glove on my bike. best of luck.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 05-03-2014, 07:51 PM
myrcrocks myrcrocks is offline
Should the cable receiver on the carb be straight, or a 45* elbow (like on the PWK)? Mine is straight...
Old 05-03-2014, 09:12 PM
john r b's Avatar
straight on both ends . no 45's
'12 XC 200 TTX Sold
Old 05-04-2014, 09:23 AM
Corey Corey is offline
Originally Posted by myrcrocks View Post
I bought the Motion Pro 10-3000 and can't get any free play in the cable at all. Did I get the wrong cable?
I haven't started it yet.
The M-P 10-3000, is the longer +4'' cable. Many bikes have this cable and it fits/works well. Check to make sure the cable end is all the way up into the slide and routing is correct.
Old 05-04-2014, 04:37 PM
I was referring to the actual brass receiver fitting on the carb, not the cable...
Old 05-05-2014, 07:25 AM
john r b's Avatar
roger that, I'm pretty sure all pwk's had straight fittings @ the carb cap.
'12 XC 200 TTX Sold
Old 05-05-2014, 11:13 AM
OK, I'm convinced that I have the wrong cable (although it was labelled 10-3000). I need something longer... The slide is definitely not closing all the way. Not even close. Photos show the cable attached to the carb. Adjusters are in all the way on both ends. One of the slide with cable attached. One showing how far the slide is open with cable attached...
EDIT--- I went on the Motion Pro website. Cable housing length for the 10-3000 is 41.73 inches, which I have. Measuring exposed cable on my OEM cable (while attached to the OEM carb with slide closed) is 2.75 inches. Exposed cable on the Motion Pro (while attached to SmartCarb with slide closed) is 2.05 inches.
Any thoughts or recommendations?
Old 05-05-2014, 12:28 PM
Diggs345's Avatar
Diggs345 Diggs345 is offline
The nipple on the end of the cable does not look to be fitted in the slide right , to my eyes anyhow , it should sit inside the recess
Old 05-05-2014, 12:31 PM
Motosportz Motosportz is offline
No it is right, you poke it through the hole and then it sits in the slot.
Old 05-05-2014, 12:34 PM
'11EC300 '11EC300 is offline
I am having the same problem.... cable is long enough, but exposed cable isn't. I hacked up my stock cable to get more exposed cable length, but it probably won't last long! I have the cable end flush with bottom of slide.
2011 EC300
2013 TXT300 Factory Replica
2014 Polaris Assault
2004 Snowhawk 600H.O.
APT SmartCarb siaknijustin Enduro Product Announcements 19 10-02-2012 08:12 AM
