Old 08-11-2014, 12:00 PM
Banned
Default Pipe dent remover
Purchased this on Ebay, well worth it! Not perfect but cheaper then replacing.
Old 08-11-2014, 01:18 PM
rubber Jonny rubber Jonny is offline
I have a similar dent tool, you need to heat the pipe more you could get much more of that dent out, I could get that at least 90% out you look like you have only got it about 50% better. You need 80-100psi and heat the pipe slowly so you can watching the dent come out so you can apply more heat in the correct area.
Old 08-12-2014, 11:35 AM
Banned
It was my first go with it. I was a little nervous but will give it a good heating next go around.
Old 08-12-2014, 12:50 PM
pscook's Avatar
pscook pscook is offline
I found with my home made death trap contraption to plug the ends, then heat the dent, and only then to apply air pressure. If I pressure it up before applying heat, the thermal expansion of the air inside the pipe overwhelms the safety measures on the plugs.
In short: Heat first then air = good.
Air first then heat = dents in garage door.
Phil
(New bike pending...)
Old 08-12-2014, 12:59 PM
thumperflipper thumperflipper is offline
Good points! Also you can engineer a built-in leak by putting a valve on the other end that you can crack open, then as you heat the pipe just watch your PSI on your gague
here we used about 30psi, much more in my comfort zone:
https://www.youtube.com/watch?v=idxX...qKv0RIp9jl6463
07 GG EC300
11 GG EC300E
Old 08-12-2014, 01:27 PM
Leo's Avatar
Leo Leo is offline
You need to remove the carbon and oil inside the pipe before in order to prevent pressure increase.
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 08-15-2014, 02:24 AM
wrench's Avatar
wrench wrench is offline
Do you have a link or contact info for the tool!
2003 GG 300EC/DE [Ohlins]
2001 GG 250XCSOLD
Old 08-15-2014, 07:40 AM
woods woods is offline
I watched a mechanic use a homemade set of plugs to get dents out of an expansion chamber. Hooked it up to air, put in 20 psi and heat the dented area with his Acetylene torch carefully. He got the dents out almost perfectly as the metal became cherry red.
Old 08-15-2014, 07:58 AM
Phaeton's Avatar
Phaeton Phaeton is offline
80-100psi YIKES!
I would stick with 20-30 and use a real torch.
Old 08-15-2014, 07:15 PM
GasGas's Avatar
GasGas GasGas is offline
Nitrogen is way safer as it does not expand like air. That is what my brother uses.
2018 EC 300
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 REVERUP Enduro Product Reviews 28 12-30-2013 09:05 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Pipe dent GasTimppa Pictures & Videos 6 11-06-2012 04:10 PM
Pipe Dent Removal savage sausage United Kingdom 22 02-21-2012 07:51 PM
Dent Removal PEB Enduro Engine - 2 stroke 7 12-27-2007 09:23 PM
