Old 09-03-2014, 05:48 PM
TavisB's Avatar
TavisB TavisB is offline
Bronze Level Site Supporter
Originally Posted by GasGas View Post
Nitrogen is way safer as it does not expand like air. That is what my brother uses.
What? It expands just like air.
[2003 Gas Gas EC250][http://www.motoadventure.me]
Old 09-03-2014, 06:24 PM
noobi's Avatar
noobi noobi is offline
At low P and T, yes, it does behave according to ideal gas laws.
At higher P and T, like 100psi and 100s of degrees C, it deviates from ideal.
I think a bigger issue with using air is not so much the unideal expansion, but the combustibility of the compressed oxygen in air.
There's a reason you avoid compressing gaseous oxygen.
Old 09-03-2014, 07:10 PM
Leo's Avatar
Leo Leo is offline
https://www.youtube.com/watch?v=sEefLnRLcRA
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 09-03-2014, 08:00 PM
TavisB's Avatar
Yeah, that is my understanding as well.
Old 09-03-2014, 08:31 PM
woods woods is offline
O2 isn't combustible. Regular air is 78% nitrogen. 21% Oxygen and trace gases.
Take a look at someone who has popped out pipes. 30 psi isn't much, only 3 atm.
Old 09-03-2014, 08:46 PM
noobi's Avatar
Technically its the oxidant. The steel pipe is the fuel.
Still incredibly dangerous stuff. You would probably get away with air, as the nitrogen would act as a suppressant, but using nitrogen instead of air is certainly safer.
30psi gauge is 2 atmospheres. There was mention of 80-100psi earlier in the thread.
Old 09-03-2014, 08:58 PM
Never see it done at 100psi. The main danger you would have at 100 psi would be the pipe blowing up in your face when heated cherry red. You are not going to get a fireball or anything. Just metal blowing up in your face.
30psi is 3 atm as most gauges measure from one. 3 on the inside pushing against one from the outside. Guess we can argue that.
Old 09-03-2014, 11:16 PM
Elvis74 Elvis74 is offline
My experience ist not the air pressure is the secret to remove the dent, it's this heat. I always used the normal small gas lamps like in the video with no good results. Last time I used a butane burner which gives much more heat and a larger area of heating. It works much better and easier to remove the dents.
Old 09-04-2014, 02:13 AM
the guy i use, uses water in the pipe
Old 09-04-2014, 05:18 AM
bkwdc's Avatar
bkwdc bkwdc is offline
Got word that Brett with BonJoesCycleSport would be at the Little Brown Jug AMA national enduro this past weekend. So I took my 2 worst pipes. One was almost flattened at the largest diameter.
Report; nice guy. Professional. Did an unbelievable recovery on very bad pipes at a great price.
Absolutely recommend.
716-773-5800
http://www.bonjoescyclesportinc.com
Or you can continue to screw around in your garage and put your eye out while leaving ripples and dents.
2011 EC300 Six Days
2010 EC300 Nambotin Replica
P3carbon fiber pipe guard Gas Gas stock pipe 08-11 REVERUP Enduro Product Reviews 28 12-30-2013 09:05 PM
Crank Remover and Crank Installer tools for EC250 Fabry Enduro Engine - 2 stroke 5 06-25-2013 07:24 PM
Pipe dent GasTimppa Pictures & Videos 6 11-06-2012 04:10 PM
Pipe Dent Removal savage sausage United Kingdom 22 02-21-2012 07:51 PM
Dent Removal PEB Enduro Engine - 2 stroke 7 12-27-2007 09:23 PM
