Is it possible to convert the clutch slave cylinder to accept dot4?
I considering the Clake SLR to get a nicer setup of the levers and hopefully a stronger lhrb. |
ive used dot 4 in my bike for years ?
03 ec300 honda cr500 94 |
Is your clutch mineral oil right now?
I have switch from mineral oil to ATF with no issues what so ever. Been doing this for years. What the US calls mineral oil is very different than what Europe does.
13 GasGas 300XC, CLake and now Rekluse 17 Beta 430 RRS, Clake 19 Vertigo 300 03 H-D Nightrain www.newoodsriders.com You Can't Out Run Death Forever But You Can Make the BASTARD Work For It! Enjoy Life, Have Fun and Play Hard |
![]() Quote:
The only danger from switching from a mineral oil to brake fluid would be if it was still going to be used as a clutch master cylinder. I was told that it could cause the clutch slave cylinder o-ring to fail. If it is used for a left hand rear brake, it will be fine. Prior to about 2006, the GasGas AJP clutch used Dot4 brake fluid.
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
![]() Quote:
You need the repair kit from before 2007 with the black seal this is for DOT4 the green one is for oil
4 strokes are only good for power generators ![]() |
![]() Quote:
Merry Christmas! .
clutch slave cylinder hydraulic seal | Boodog | Enduro Engine - 2 stroke | 3 | 07-08-2013 05:45 PM |
Rekluse Adjustable Slave Cylinder | Fred1956 | Enduro Product Reviews | 16 | 03-27-2013 09:54 AM |
Rekluse adjustable slave cylinder | Fred1956 | Enduro Product Announcements | 0 | 11-28-2012 08:50 PM |
Clutch Slave Cylinder Rebuild | newgaser | Enduro Engine - 2 stroke | 5 | 03-17-2012 08:30 AM |
slave cylinder | new gas gas | Enduro Engine - 2 stroke | 0 | 11-14-2008 04:47 PM |
