Old 03-19-2008, 04:54 PM
moff747 moff747 is offline
Default M6 hole under engine?
I noticed when changing my gear oil an M6 threaded hole on the underside of the engine, Anyone know what it is? theres nothing in it just a threaded hole. Is this a breather or should it be plugged?
Old 03-19-2008, 06:46 PM
Rick's Avatar
Rick Rick is offline
If I'm not mistaken all theGasGas engines have another drain hole that is located towards the front of the motor under the crank area. That is used to drain any thing that might happen to get into main bearing area. That should have a bolt with a copper washer. Other than that an oil drain plug for the tranny. Anything else could just be a tapped hole with threads for mounting the cases to during assy process?
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 03-19-2008, 10:48 PM
Treesmacker Treesmacker is offline
on the pre-2005 bike it is a breather hole to the ign. and also a fixture hole for ass'y. Some guy's plug it with a screw.
Hole In Cylinder PEB Enduro Engine - 2 stroke 1 09-07-2010 10:19 AM
Ignition drain hole. roostafish Enduro Engine - 2 stroke 3 11-28-2008 08:08 PM
2008 Swing arm threaded hole ? REVERUP Enduro Other... 7 11-21-2008 07:36 PM
07 GG300EC - small hole at btm. of engine? g dirt Enduro Engine - 2 stroke 4 02-26-2008 05:48 AM
Mounting hole locations for Scotts Steering Stabilizer SpeedyManiac General Discussions & Announcements 7 01-23-2007 01:33 PM
