Old 03-10-2015, 06:33 PM
spooly's Avatar
spooly spooly is offline
I also have two leaking fork caps only had a full suspension rebuild 2 races ago.. There's always something.!!
Old 03-11-2015, 01:45 AM
Fastboysparky's Avatar
Fastboysparky Fastboysparky is offline
Same here. Had new fork seal before xmas and now they leaking again. Going to try the plastic bottle trick on them
Old 03-11-2015, 05:02 AM
spooly's Avatar
My caps are leaking because the rebound screws had split and my suspension guy took the screw out and cut the top off it a made a new head so I could adjust um .it was worth a try anyway I spouse but the two are leaking now and have to be replaced luckily iv found replacements for ok money. .
Old 03-11-2015, 05:04 AM
spooly's Avatar
Originally Posted by Fastboysparky View Post
Reeds price was 44 pound. Not as it has come out above.
Who u using for parts??
Old 03-11-2015, 12:49 PM
Sadmx. Mine has vforce3 which has like a twin petal. Other models have vforce1 which are different.
Old 03-11-2015, 01:00 PM
I have just done a compression test and was getting 160 psi for 10 kicks. It's not bad so will not be stripping top end.
Old 03-14-2015, 05:08 PM
I fitted the new reeds today and took her for a blast, saddly no difference. I removed the air filter (just to try anything) and tried again, still no difference. I can only think that it's got to be electrical.
Sent from my i phone whilst doing a tail whip.
Old 03-14-2015, 05:32 PM
spooly's Avatar
Same scenario here mate.. word for word. . And I actually went through the electrical connections too today still no difference. . Im going to take the barrel off again and inspect and if that doesn't work it has to be electrical
Old 03-14-2015, 06:43 PM
Let me know if you have success. I may have found an ecu, the guy is sending me pics of it tomorrow and if it's the same as mine then I will have it.
Old 03-14-2015, 07:12 PM
spooly's Avatar
Fingers crossed
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
EC 300 Rattling & power loss ??? Porkyblader Enduro Engine - 2 stroke 7 09-09-2011 09:11 AM
Your 300 Power loss solution? socalscott Enduro Engine - 2 stroke 3 07-14-2011 08:39 PM
Old gas and power loss? EcEvan03 General Discussions & Announcements 16 04-27-2011 06:40 PM
power loss glassman581 Enduro Intake/Carburetion - 2 stroke 3 03-22-2011 11:19 AM
