Old 04-04-2008, 07:47 PM
eff's Avatar
eff eff is offline
Default Head bolts - no access?
My top-end job got stopped before even got the head off. I can't get a wrench on the front right bolt. WTF That really pisses me off because it's bad engineering.
Now I assume I'm not the only one with this issue, but I'm shocked that no one has posted about it before. What are you guys doing to get the bolt off and better yet how in the hell do you torque the thing?
Thanks for the help.
2004 GasGas DE250
Old 04-04-2008, 08:46 PM
steve steve is offline
My '06 has room,what year is yours?Maybe grind a wrench with a short pipe.
Old 04-04-2008, 09:38 PM
eff's Avatar
eff eff is offline
Mine is an '04. I guess I'm going to have to pick a box-end and grind it down.
2004 GasGas DE250
Old 04-05-2008, 05:02 AM
blitz11's Avatar
blitz11 blitz11 is offline
And when you're done, replace the Hex Head Bolts with Allen or Torx. That way, clearance won't be a problem next time.
It isn't a problem, it's an opportunity to modify and make it better. My 2002 used Allen bolts, so you can probably include those in your GG order. S
Sometimes newer isn't better.
blitz
Old 04-05-2008, 05:48 AM
eff's Avatar
eff eff is offline
blitz
Good perspective and that would make the problem go away.
2004 GasGas DE250
Old 04-05-2008, 06:13 AM
Use a good wrench so not to strip the bolt!!!!!
Old 04-05-2008, 08:29 AM
You have to take the spigot off the head first. Always get a new gasket for that with the other parts. For the front cylinder studs under the PV covers, you have to grind a box wrench down slightly.
Old 04-05-2008, 11:41 AM
eff's Avatar
eff eff is offline
The spigot wasn't my issue. It was the base for the spigot and the front motor mount, but mostly due to the spigot base on the head. It seems the area just need to be machined away a bit. I ground down a box wrench and it worked like a charm.
Anyways, I have the bolt loose and will start over tonight when my wife goes to work (license to play on the dirt bike).
2004 GasGas DE250
Old 04-05-2008, 04:11 PM
eff's Avatar
eff eff is offline
Thumbs up
Not much activity on here today. So I'll post some progress. Took the power valve covers and I was shocked at how clean it is in there. My pipe is always spoogy and I figured my power valve would be too.
2004 GasGas DE250
Old 04-06-2008, 08:35 AM
iancp5's Avatar
iancp5 iancp5 is offline
That's odd I can get one on
Torquing Bolts wbagwell Enduro Engine - 2 stroke 7 06-10-2014 07:36 AM
Clutch / Brake Banjo Bolts iancp5 Enduro Chassis & Body 2 11-24-2009 04:14 AM
Ec250 Cylinder Head Bolts? Elliker Enduro Engine - 2 stroke 8 01-24-2009 04:51 AM
Exhaust Spigot Bolts eff Enduro Engine - 2 stroke 9 08-08-2008 06:38 AM
Periodically remove and re-fit all bolts? stay_upright General Discussions & Announcements 2 01-14-2008 07:56 PM
