Old 10-13-2015, 02:16 PM
poelinca's Avatar
poelinca poelinca is offline
Default Clutch covers and part numbers, witch years fit witch ?
I'm in the market for a new clutch cover. The manual states that the part number i'm looking for '14 is ME22010GG.
Seller A states that the same part number fits '12 to '15. It also states that ME250732002 will fit 96 to '11. It also states the different part numbers for the '14 and '15 models are because of a new alloy used, but the shape did not change.
It also states that the clutch cover gasket ME22015GG will fit '00 to '15 models.
Seller B states that ME250732002, ME15000003011, ME250332002, ME25632002 and MFS450732002 will fit 96 to '13. It lists separately the ME22010GG for the '14 model (that i'm after, and does not have one in stock).
Seller C states that ME22010GG, ME15000003011, ME250332002 fit each other.
Who is right and who is wrong ? Because the overlapping '11 do '13 years means the same clutch cover will fit 96 yo '15 and that is hard to believe.
'14 EC300
Old 10-13-2015, 03:25 PM
scratch250's Avatar
scratch250 scratch250 is offline
I ride a 12 250 and found a used rekluse cover on ebay for cheap. Not sure the part#, but u might research that option. My stock cover was a leaky bastard.
Old 10-13-2015, 03:49 PM
poelinca's Avatar
Might worth a try, but i need to know witch one fits witch. Did you get your Rekluse cover for years before '12 or later ?
p.s. prices for the above mentioned sellers are not that high tough, they range between 40 and 50 euros brand new
'14 EC300
Old 10-13-2015, 05:25 PM
scratch250's Avatar
Sorry don't remember details on it. I'll try and find out.
Old 10-14-2015, 08:44 AM
poelinca's Avatar
This is a very very messy job.
The Rekluse part number for the cover listed on gasgasmotos.es site, is ME650203013. They also state that it will fit EC300 from '00 till '15.
So if the same Rekluse cover fits '00 to '15, that means '13 original cover should fit '14 model right ?
'14 EC300
Old 10-14-2015, 07:50 PM
hamilton's Avatar
hamilton hamilton is offline
I know 12-15 will fit. 12 cover was plastic and prone to leaks.
13 cover didn't have good splash oil direction.
14-15 cover would be my choice, but the older covers would work in a pinch.
15 GASGAS EC 250
19 Sherco SE 125R
Old 10-15-2015, 03:13 AM
poelinca's Avatar
Problem with the 14-15 covers is that nobody has them in Europe. I saw one in Australia, maybe some in US (cat tell for sure) but shipment coupled with other bits and pieces i also need to order would go over my budget. With the factory closed, i'm looking into alternatives since we can't tell when they will start producing and if they ever start producing.
The one on stock i found in Spain fits 01 to 13, and made of aluminium. So based on your info, if it fits 12 and 13 it should also fit 14 and 15 right ?
Thanks, this is great news
'14 EC300
Old 10-15-2015, 12:06 PM
Anders Anders is offline
I have a brand new plastic one that you can have very cheap if that has any interest. I am in Norway.
Sent fra min GT-I9295 via Tapatalk
Old 10-15-2015, 03:40 PM
poelinca's Avatar
Yes, I am interested. I sent you a PM.
Thanks
'14 EC300
Part Numbers 12Bravo Enduro Other... 4 10-25-2015 06:29 AM
NEDW and NEDJ part numbers and measurements thanks Stevel Enduro Intake/Carburetion - 2 stroke 4 04-10-2015 03:36 AM
Nissin Brake Pad Part Numbers 2011 Moto7man Enduro Chassis & Body 6 01-19-2014 05:40 PM
Witch Spring.... Packman Enduro Suspension 1 06-07-2013 01:15 PM
need main bearing part numbers mxdj2003 Enduro Engine - 2 stroke 0 03-15-2010 05:07 PM
