Float bowl drain bolt hitting case
Anybody else have this going on? I'm not sure if it has always been like this or not. I know it's always been close...
2013 GasGas XC300E 2005 YZ290 1973 Honda CB175 1997 KX60 1983 Yami Tri-Zinger 1984 Suzuki Alt 50 1969 Trail 90 1971 Trail 90 1972 Trail 90 |
Loosen the sub frame, lift up on the rear and tighten the bolts.
I'll give that a go. Thanks. I'm still on the plastic subframe. If that matters.
After a while, they can sag a little .
Help needed - EC 300 float bowl leaking | Speedchop | Enduro Engine - 2 stroke | 7 | 09-27-2019 01:34 PM |
Carb float bowl screws? | Niall-griffiths | Enduro Intake/Carburetion - 2 stroke | 5 | 03-06-2014 07:52 PM |
float bowl hight | bonkeye | Enduro Intake/Carburetion - 2 stroke | 2 | 04-26-2012 03:01 AM |
oil drain bolt in case | jyellard | Enduro Engine - 2 stroke | 11 | 10-13-2009 04:39 AM |
Float Bowl HELP! | gasIdaho | Enduro Engine - 2 stroke | 3 | 07-18-2007 09:30 PM |
