Old 03-27-2017, 03:05 AM
Rampart Rampart is offline
Default EC300 new piston issue
Hello
i've got metered my cylinder - 72,05mm. Limit for it 72,1mm as manual says.
BUT biggest piston size will have 71,95mm what will give 0,1 mm clearance - and it is out of limit as manual says! What should i do in this case?
Old 03-27-2017, 05:24 PM
dANbOT's Avatar
dANbOT dANbOT is offline
I just took a look on ebay, and saw Wossner pistons in 72.01 and 72.02 sizes if that helps
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 03-28-2017, 03:28 AM
72.01 will be perfect! Can you provide link? Are some one using them? Is this original piston?
Old 03-28-2017, 04:34 AM
Getoviq95 Getoviq95 is offline
Try wiseco ,they're only one size .I belive they are 72,00 .
Old 03-28-2017, 08:28 AM
dANbOT's Avatar
http://m.ebay.com/itm/Wossner-Piston...120?nav=SEARCH
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 03-28-2017, 08:31 AM
$197.99 + $46.50 for shipping = sounds a little bit crazy
Thank you for link
Old 03-28-2017, 08:55 AM
dANbOT's Avatar
Well, it was only an example that the size is available. Wossner is about the best Piston you can put in your gasser, should be available from many locations. Perhaps a better price can be found.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 03-28-2017, 09:24 AM
OK, thx, i understand.
But how can you tell that it fits? Diameter is ok, but how about piston pin to top distance?
Old 03-28-2017, 09:54 AM
dANbOT's Avatar
Wossner makes these for our Gasgas bikes, no need to worry about that.
Here is their website, so you can look up fitment for your specific bike, and then chose diameter. I believe they offer A through D sizing. Once you have the part number you can search for a vendor anywhere you want.
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 03-28-2017, 11:33 AM
My 250 uses a ktm piston.
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
Ec300 rattle/power valve issue Smithwoodwest Enduro Engine - 2 stroke 6 12-22-2016 07:46 PM
Piston Size EC300 stian Enduro Engine - 2 stroke 26 11-28-2014 06:46 AM
2011 ec300 kick start issue bigtoe Enduro Engine - 2 stroke 10 05-19-2014 11:39 AM
Help 1999 ec300 fork bleeding issue kingsizerizla Enduro Suspension 1 01-28-2014 04:58 PM
ec300 piston kits? motopsycho87 Enduro Engine - 2 stroke 2 08-01-2013 05:20 AM
