Old 06-11-2017, 10:49 PM
ljdb ljdb is offline
Default New to gasgas. Just purchased 2015 ec250
Hi guys I'm new to gasgas and just purchased a near new 2015 ec250 e start over here in Australia. Being a mechanic I wasn't happy with the way the previous owner had put it together so I pulled it down and went right over it.
So what are some of the things I need to look out for or do to improve the bike. I've already need to play around with the float level in the carb as it keep leaking out the overflow while on the side stand. I also moves the map switch higher up to keep it away from water and to better protected.
Loving the bike so far Iv only travelled 20klm form a total of 90 on the bike.
Old 06-12-2017, 03:54 AM
poelinca's Avatar
poelinca poelinca is offline
Hi and welcome to the family!
If the bike is running fine, and you are loving it ... why do you want to "improve" it ? Just ride it!
I'd do the usual, change the fluids, grease the bearings, etc, ride it hard for a while, then see what needs to be done.
'14 EC300
Old 06-12-2017, 07:28 AM
swazi_matt swazi_matt is online now
check that the rear brake hose is not rubbing on the engine where it loops around
Old 06-12-2017, 02:10 PM
Not so much improve the bike overall but things I need to do to make sure I don't get into trouble out riding the trails Like what swazi_matt mentioned. Over time issue arise I'm just trying get on top of them before it's to late. The float still needs a little tweaking as fuel strickles out while on the stand and it doesn't rev out cleanly
Old 06-12-2017, 02:50 PM
john r b's Avatar
john r b john r b is offline
Welcome, What jetting are you running?
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 06-12-2017, 03:04 PM
Welcome!!
Matt
1999 GG EC 250 Six Days
1999 Cagiva Gran Canyon
2001 Aprilia Falco
Old 06-12-2017, 05:35 PM
Thanks guys, ive been a fan of gasgas for awhile but never brought one due to lack of dealers and parts availability. This one was too good to pass up on.
The jetting is stock 175 main, 42 pilot, n1ef needle. Im going to get the float level right first before playing with the jetting. It runs fine if I thrash it but as soon as I easy up it(trail pace) it doesn't rev clean over 3/4 throttle.
Old 06-13-2017, 01:32 AM
Anders Anders is online now
Hello from Norway, and welcome!
I am very happy with my 15 model. It's a 200, but apart from that I guess they are pretty much the same bike. Here are some points that I have done to mine, many of them to avoid destroying expensive parts:
*As I am old and slow, I have revalved the fork to get it softer / plusher. The Reiger rear shock is very good as it is, so I have never revalved that, just serviced it a couple of times.
*I have put on a Lectron carb, mostly because I had it from my previous bike and am very fond of it.
*I use T-Lock (a Swedish competitor to Tubliss) to get tubeless wheels. Very nice, as you save some rotating mass compared to mousse. I usually run low pressure, 5 - 10 psi.
*Bulletproof design radiator braces. I need them from time to time. Last weekend I crashed and even bent the brace a little. Can't say how damaged the radiator would have been without a brace, most likely I would have had to replace it.
*I have removed all switches from the handlebar, and run only a stop switch that is integrated in the brake pump clamp. I tend to wreck my switches nd they are expensive. I have placed the map switch on a radiator hose, as some bikes have from the factory. Mine was originally placed on the handlebar.
*I have also removed (or rather not replaced the completely destroyed) tail light. Gets destroyed sooner or later.
*Short Jitsie levers.
*Aluminium handguards.
*Last winter I bought an Enduro-Tech headlight. Expensive, but very good. I use it only during winter, during summer I run the OEM lamp (as it isn't dark outside when I ride).
*TM Design chain slider and chain guard. Lasts a lot longer than OEM, but are also more expensive.
I think you will be very happy with your 15 model. Mine has run approx 115 hours now and sure shows signs of being used, but no problems so far.
Old 06-13-2017, 01:55 AM
VilluEST VilluEST is offline
Welcome! GasGas makes awesome enduro bikes and I'm sure you'll start to love it!
If you want really good low end torque, I would suggest you to buy slide #6, the difference between original #7 and #6 is huge. Pulls almost like 300 now, super low end. My jetting is currently 182 main, 42 pilot and N3CJ needle. It's smooth, very good low and top end and does not take much fuel.
Old 06-13-2017, 10:45 AM
Moto7man Moto7man is offline
Welcome to the forum! You will like it.
―Comedian Lewis Black
-Unknown Sardaukar
2015 GasGas XC250E Cycleking Used Bikes 3 10-19-2016 04:55 AM
2015 GasGas noobi General Discussions & Announcements 86 03-20-2016 09:22 PM
Any ideas on 2015 EC250 jetting? MOGaser Enduro Intake/Carburetion - 2 stroke 2 12-20-2014 06:40 PM
2015 gasgas 450 bkwdc General Discussions & Announcements 7 11-12-2014 02:09 AM
Newbie - Just purchased 250ec Chilli United Kingdom 7 01-25-2010 11:19 AM
