Old 05-03-2018, 11:47 PM
Default Steering stem race. Remind me.
Have to change a mates soon. Can you tap the lower race out of the frame from the top? (2010)
Maybe it just overhangs? I've had to use the welder to shrink them before but I'd like to not have to take it over.
I've ground grooves fore and art before to make the next time more easy for the next owner. I'm nice like that.
Cheers.
Old 05-04-2018, 12:20 AM
Me too! But it is still usually me that owns the bike and changes them out again!
I am pretty sure gg leave enough lip on the frame to tap them out. I have ground out groove before removing the race on other bikes and cleaned them up once the race was out too with a barrel shaped die grinding bit and a steady hand.
Old 05-04-2018, 02:55 AM
Anders Anders is offline
Cheers.
The ones that I have replaced (2006 and 2015) have been tapped out from the top, no problems there.
Old 05-04-2018, 04:12 AM
Shweet. Thanks guys. Might tell him to do that then bring the stem to me for some precision cutoff wheel action. I'm like a surgeon with a grinder.
Steering stem help GGRider01 Enduro Suspension 3 12-02-2015 10:55 PM
top nut on steering stem knobbyboy Enduro Chassis & Body 9 09-16-2014 09:06 PM
Steering Stem Nut Cberg Enduro Chassis & Body 2 04-03-2014 07:57 PM
Steering stem material? Harry Enduro Chassis & Body 0 11-02-2011 04:08 AM
