Old 05-07-2018, 09:42 AM
Enduroger's Avatar
Enduroger Enduroger is offline
Originally Posted by Gottsell View Post
Is it a ground cabel the black that come with the battery?
I thought that it was a replace for the thiner + cabel to start engine.
I'm not sure actually. I think you might be right that it replaces the + cable. Maybe i have misunderstood since lots of people have been talking about the ground. And it also says "negativo bateria" on the bag the cable came in.
But it made a big difference for me to only replace the ground and using the old battery.
2018 EC250
2004 EC200
Old 06-22-2018, 12:03 PM
Originally Posted by Gibnut View Post
I have also recently replaced starter mount - earth, battery positive - starter relay & relay - starter motor cables with 8mm copper core wire & the starter now works like a Beta. Cold, hot in gear or neutral.
Highly recommended.
My CDI is updated and the rotor is th eone with the bigger recess. I replaced the battery with a Shido, then added a ground cable exactly like shown in the pics above. I also added a thicker gnd cable to the battery.
Then I took the ignition cover off, cleanded everything, put a bit of fresh grease on the gears but still no improvement. My dealer has no clue and I admit I give up!
When you say you replaced the starter relay what did you take instead? Another new OEM starter relay or an aftermerket product?
Thx
Doc
Old 06-22-2018, 07:21 PM
SS109 SS109 is online now
Thx
Doc
I would add a larger power cable as well. Also, did you replace the battery with the same size or one with ampere hour battery?
Old 06-23-2018, 02:40 AM
Gibnut Gibnut is offline
Fellas, must?ve had a lucky day above - the starter is still dicking around.
The bike starts first kick when cold but the starter spins & spins. This must be a weak spark if starting cold on the button, no?
Anyways, I reset my plug gap to the upper range of the manual - new BR8EG, 0.8mm - and the bike started cold on the stand with the choke on with a short stab of the start button.
I checked the battery & it?s charging at 13.63v @ approx 3000rpm & is holding 13.43v static.
Fatter spark? Dunno, but it started, so that?s a, er, start...
Gas Gas 2018 EC250 Six Days - sold
Old 06-23-2018, 01:54 PM
Ok, the + cable is still the original one. Following a dealers advice I installed exactly the same battery just that it is a Shido.
@Gibnut: my starter doesnt spin the engine though the voltage was always around 13 volts. It turns just a bit then blocks and makes a whining sound. Then I wait a few seconds and sometimes it turns over the engine quite well. the warmer the engine is the easier the starter turns it over...
Old 06-23-2018, 07:44 PM
I've come to the conclusion that the electric start on these is largely decorative.
I have sent a photo of my CDI with the serial to a dealer to check if it has been upgraded, but havent heard back as yet. Fingers crossed it might need an upgrade to make it work properly.
Old 06-24-2018, 02:44 AM
The upgrade on mine didnt change anything.
Old 06-24-2018, 04:39 AM
That makes me sad. I kind of like the idea of an electric leg.
Old 06-24-2018, 07:49 AM
Just take the time to get it sorted. Larger + and - wiring, larger ampere hour battery, and updated CDI seems to have fixed most. Of course, the dealer should be figuring it out as it is a new bike. You listening GasGas?
Old 06-24-2018, 10:09 PM
Default Eectric starter 2018?s..
2018 Starter Fix Thread - Continued. webmaster Enduro Electrical & Wiring 162 04-26-2023 02:57 AM
2018 Stoby General Discussions & Announcements 23 04-18-2018 04:07 PM
2018 Batteries and Starter Doesnt work! markwoodlief Enduro Electrical & Wiring 81 11-30-2017 03:50 PM
2018 Starter Delete nhgas Enduro Electrical & Wiring 1 11-10-2017 07:58 PM
