Old 07-06-2018, 05:50 PM
Jat Jat is offline
Default Expansion chamber
anyone tried fitting a kx expansion chamber to a ec300, got a cheap kx250 pipe available hoping it will fit with some mods re welding mounts etc
Old 07-06-2018, 06:19 PM
SS109 SS109 is offline
You know you can find a used pipe pretty reasonable, right? I even have a couple of good ones. What bike do you have?
Old 07-06-2018, 08:33 PM
Jat Jat is offline
Live in australia so bit more limited with options, new pipe from usa works out at about $400 inc freight.
Have chance to grab a brand new kx250 gnarly and powercore muffler for$200 but not sure if it can be made to fit my 2009 ec300.
Old 07-07-2018, 02:35 PM
(F5) (F5) is online now
No point putting a pipe designed for a 250 mxer on an enduro 300.
Spend a bit more or get someone to fix yours and you will be happier with the results.
Old 05-06-2020, 12:51 PM
comeragh's Avatar
comeragh comeragh is offline
Default What is this pipe on expansion Chamber for .
Bought a exhaust cheap NOS hoping it would my 1999 ec 250 .
There is a strange pipe coming off it .
What is it for .Have never seen anything like it .
Old 05-06-2020, 01:57 PM
hannesd hannesd is offline
cut that tube off, it's for emission regulations.
are you sure, this pipe doesn't have a restriction build in?
or a catalyc convertor like some bikes have from factory (also for emissions)?
Old 05-06-2020, 02:07 PM
comeragh's Avatar
Thanks for reply.I will cut it and weld it up.Seems hollow .I will try and look inside.Its heavier construction than the original rotted Messico.
Old 05-06-2020, 03:06 PM
It will have a catalytic converter that needs to be cut out. I THINK it is located at the large weld on the pipe.
Old 05-06-2020, 03:50 PM
comeragh's Avatar
What do you mean by large weld .Thanks .
Old 05-06-2020, 04:04 PM
comeragh's Avatar
http://www.gasgasrider.org/forum/sho...t=13625&page=2
Just found a post on this .Seems pretty simple to remove cat .Thanks for info.
Ec300 expansion chamber Trigga Enduro Engine - 2 stroke 1 05-06-2015 01:04 PM
'12 300 expansion chamber. nato General Discussions & Announcements 4 08-10-2013 06:14 AM
Expansion Chamber Springs ddab Enduro Engine - 2 stroke 3 06-06-2013 12:02 PM
Expansion chamber x-over Harry Enduro Engine - 2 stroke 2 04-15-2011 10:47 AM
Super Hot Expansion Chamber builtogo Other GasGas Bikes/Quads 5 05-11-2009 05:45 AM
