#11
Um, it's the most common on that suits 90% of common jap bikes. Use a dab of grease on the face to crank end to prevent damage.
This will explain https://www.motoxparts.co.nz/p/flywh...rsal-nac-tools 27x1mm I like the motion-pro one, simple robust, can give it a shock with a hammer. Like go hold flywheel with this to undo. Have to position carefully so don't snag pulsar coil. Available from supercheap etc for not much. https://www.google.com/search?client...d7j8NovOpOvkM:
#12
Julian - crank main bearings and seals can be bought through industrial bearing supply shops such as Saeco Wilson NZ.
Connecting rod is the same as Honda Cr250 (check years) Attached is a list of bearings and seals for my 02 EC300 |
#13
Awesome, thanks guys. Aiming to crack into tear down on the weekend.
If you're in my neck I owe you a beer. |
#14
I used Saeco for 20 years but now their prices hammer the chap off the street so they can give thier trade customers 50% discount as a starting point
#15
Yep, that'll do it...
Crank bearing is toast. To confirm, I should: - get the crank rebuilt - see if any other bearings in the cases are feeling rough - order new bearings and seals - might as well do top end while i'm in here (although top end isn't that old) anything else i should check while i'm in here? cheers |
#16
I would replace all bearings and seals while it is split. If the top end isn?t that old you can do it in the frame later easily enough. Last thing you want to do is strip it down in a months time because a bearing did not get replaced. Check the gears for wear and chipping as well. Make sure the little plastic guide that the shift shaft scorpion rides on is in good shape. The early four strokes had a alloy one that held its shape better. They are not hard to make on a lathe though.
#17
Check gearbox bearing but they live in oil and should really last the lifetime of the bike.
Measure the ring end gap. 0.5 to 0.8mm on a 300. Mine was barely worn after several years so it went back. Ran great today, idle issue gone.
Tags |
big end, bottom end, crank, crankshaft, rebuild |
No bottom end | Mostin3 | Enduro Engine - 2 stroke | 29 | 02-11-2018 02:47 PM |
Wtb 03 250 bottom end | papagasgas | "Wanted to Buy" & "Want To Trade" | 0 | 08-30-2015 02:44 PM |
'05 125 bottom end | marshalls113 | Parts | 0 | 04-14-2014 08:16 PM |
bottom end condition? | knobbyboy | Enduro Engine - 2 stroke | 10 | 01-12-2013 06:32 PM |
