Old 12-21-2018, 07:25 PM
jbmurc jbmurc is offline
Default New Gas gas 450cc owner -metallic oil darn!!!!
Just purchased Road approved 2007 Gasgas 450 Pampera and now I know why it was way cheaper (around 50% less) than comparable KTM450 bikes in the market ...
Gutted as on the test ride the motor seemed to be run fine with no major noises ... was on a gravel road and didn't have time to really go for a long ride.
Now after replacing oil and paper filter and checking metal screen far to many metal flakes copper to a grey metal with heaps of metallic dust/fine meta pieces ... to not be something major
idle the motor hasn't any major noises ...underload I believe there is a deep knocking from either top-end or Big-end Connecting rod
Power wise the bike runs well ...is what sold me think the donk was healthy
...NOW not sure what to do just got a new front tyre road reg >>> gutted
I guess the only option outside just selling it off in parts is pull the motor out and try to work out where all the metal is coming from ...
Old 12-25-2018, 04:00 PM
Harry's Avatar
Harry Harry is offline
Where are you based? I have a 400 undergoing surgery
Old 12-28-2018, 10:33 PM
New Zealand - I'm now confident the bottom end is fine and it was more so the previous owner having some old 91 fuel and just some detention and the alloy bash plate making engine noise louder
my last bike was a two-stroke so use to muck quieter engine noise ..
Engine Oil was very black old (useless previous owner !!!) have run an flushed using ATF trans field cleaned/replaced both filters ...
will do another Oil change in 500kms see how the oil looks hoping for pretty clean
I looked through the intake manifold and I see the opposite bore still had cross hatch bore makings so with only 6000kms on the clock pretty mint engine IMHO
biggest pieces were gear alloys .. overall bike is running ... clocking up some time working on the Gasgas(Glad I'm not paying for it) .. Carb stripped and cleaned now running A32 needle clip down to midpoint- 136 main jet 38 idle jet..
Gearing no good for 100km/h road cruising so just fitted 46 rear to match the 14 front giving me 6.5% higher top speed over the 14/49 combo it ran.(should bring 100km/h revs down to just under 6,000rpm)
just changing fork oil took out 750mls ... someone has played around with these stock conventional 45 Zorks ... nothing like the diagram ... twin springs 250mm plastic spacer at the top ?
Old 12-29-2018, 09:59 PM
Harry's Avatar
Hi, This sounds like the Pampera if it has carb and conventional forks?
Old 12-30-2018, 07:11 PM
Yes it sure is
Metallic residue on bolt magnet stabak Enduro Engine - 2 stroke 3 04-15-2015 02:41 PM
2003/2005 FSE 450cc oil leaking problem Ladse Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-03-2014 01:43 PM
New owner of a 99 EC 300 boardrider247 General Discussions & Announcements 12 07-11-2013 07:04 PM
New EC/O 200 Owner lankydoug General Discussions & Announcements 3 08-02-2010 09:30 AM
Darn it...new bike blues SpeedyManiac General Discussions & Announcements 10 04-30-2009 12:13 PM
