Old 04-29-2019, 10:11 AM
ian1987 ian1987 is offline
Default Heavy Rider
I weigh about 18 stone (115kg).
I notice my 2008 EC300 is a bit soft at the rear. Is it as simple as fitting a heavier spring?
If so which grade do I need?
Old 04-30-2019, 01:04 AM
Anders Anders is online now
A heavier spring is certainly needed. You might also experience a need for higher rebound damping when the heavier spring is used.
As to the spring rate, I would guess somewhere above 6kg/mm.
A few days back we had this thread.
But spring rates used in the 2012 and later differ from the rates used i 2011 and earlier due to a difference in the linkage.
Please check the rate with someone more knwledgeable than me. There are some spring calculators around, e.g. Racetech. You should also do the same at the front (change the springs for heavier ones).
Old 04-30-2019, 07:58 AM
You need to also consider what type of riding you will be doing. If you are a trail rider go for a softer spring and stiffer if you are a racer.
Regardless the stock springs are too soft for your weight. From my experience the racetech calculator tends to recommend stiffer springs.
Is the 2013 EC 300 too heavy? jpgibson General Discussions & Announcements 54 12-24-2018 08:13 AM
200 riders, how big/heavy are you? GMP General Discussions & Announcements 31 11-05-2011 12:13 PM
Are stock 07' springs to heavy for a 150lb rider? noobi Enduro Suspension 6 07-08-2010 12:46 PM
Something heavy in my exhaust! iancp5 Enduro Engine - 2 stroke 2 04-08-2009 11:56 AM
Heavy Duty vs. Ultra Heavy Duty Tubes gasIdaho Enduro Chassis & Body 4 03-07-2007 05:49 AM
