Old 05-29-2017, 05:13 PM
Originally Posted by Rampart View Post
Thanks all, but i don't understand - should i install rectifier with fan, or i can install it without rectifier?
Does your bike have a battery? Yes = no rectifier / no= use rectifier
Old 05-30-2017, 04:31 AM
Rampart Rampart is offline
OK, thank you all
Old 05-30-2017, 11:21 AM
Neil E. Neil E. is offline
Another thing to consider: Even if you have a battery, using the separate rectifier will put the fan load on your AC windings. This will prevent the fan load from running down your battery.
Old 05-31-2017, 11:27 AM
Can someone tell - how many amperes have original gg fan?
Old 07-26-2019, 04:48 PM
clbuff clbuff is offline
Hi, I have a 2011 EC300 E (electric start) and I'm planning to install a fan and I think is a good idea to have a DC source parallel to the original sistem so the fan will not drain the battery, that is possible?
Old 07-29-2019, 11:58 AM
Yes, just hook up the rectifier input to the AC wiring (yellow plus chassis ground). Connect the rectifier output only to your fan through a switch. If you use a thermoswitch make sure it has two connection terminals so that your circuit will be isolated from ground.
Old 08-10-2019, 11:11 AM
Moto7man Moto7man is online now
Default Add Fan Question
This is kind of a dumb question but I want to to mount a fan on my 84 RM 250. I am going to use a Spal Fan with a switch. This is the stator before restoration. My stator only has the two AC wires. Do I need a new stator with dedicated power source wires? Like in the video below,
URL="https://youtu.be/zEQu-JMfUSg"]https://youtu.be/zEQu-JMfUSg[/URL]
―Comedian Lewis Black
-Unknown Sardaukar
Old 08-10-2019, 02:28 PM
You need a stator with a lighting coil.
Your current setup won't support the fan.
Old 08-10-2019, 02:32 PM
Default Stator
That is what I thought. Do you Trailtech would have one?
-Unknown Sardaukar
Old 08-10-2019, 04:05 PM
https://www.rickystator.com/product/.../suzuki?page=2
Or, lighting coil off Suzuki RMX.
12 EC300 mapping question knocklife Enduro Electrical & Wiring 1 09-24-2014 12:45 AM
06 EC300 Question ECTim Enduro Electrical & Wiring 5 08-27-2014 04:29 PM
Starter question 2011 EC300 iamovru Enduro Electrical & Wiring 3 02-17-2014 12:01 PM
Gas Gas ec300 plastics question. Tricky Enduro Chassis & Body 4 01-07-2014 10:55 AM
EC300 Dim Electrics Question rogerc Enduro Electrical & Wiring 2 03-02-2009 11:47 AM
