Old 11-29-2019, 05:28 PM
rodent's Avatar
rodent rodent is offline
I picked my scooter up from the dealers after having the "correct" nut fitted, the mechanic told me that the there is actually nothing wrong with "incorrect" nut and it is exactly the same as the "slotted or black" nut.
He went on to say that allegedly the problem was just that the nuts were not torqued into place properly at the factory.
Your mileage may vary.
PS: On my bike the nut cannot be seen through the oil level hole with oil in the bike.
Edit: I took my bike off the trailer leaned it over to the left to let any oil drain away, and yes you can see the nut through the oil level hole. It's toward the upper left.
Old 11-30-2019, 03:47 PM
yowie05 yowie05 is offline
Took my bike in to dealer 4 weeks ago tomorrow. Still no word on when I'll be getting it back. If you can get the nut yaself I would do that.
19 EC300 Six Days
04 EC300
00 KX125
06 KX450(deceased)
Old 12-03-2019, 01:08 PM
I bought a new EC 300/19 last week and asked my dealer if the nut needs to be checked but he said no.
He said its a later 2019 model and it is not affected. How can he know? Do they have a list with VIN numbers. I doubt he tells the truth...
Old 12-03-2019, 01:43 PM
Anders Anders is offline
If you read the pdf attached to the first post, you will find the list of VIN numbers
Old 12-04-2019, 05:27 AM
Thanks Anders, I somehow managed to miss that one...
Old 12-09-2019, 11:24 AM
My new 300's VIN belongs to the affected lot
So what you are saying is I can see the nut through the oil level sight glass if the oil is drained ??? You mean I can see it and identify if it is the correct one ???
Pls let me know asap.
edit: is it a normal nut or a left hand threaded one (tightening counter clock wise) ?
Old 12-09-2019, 12:46 PM
rodent's Avatar
Yes you can see it through the hole, just lean your bike to the left to let the oil drain away and the nut is to the upper left. I can see that mine is silver with the "LHT" marking cut out of the corners. So if it's black or silver with the cuts it's correct, yes it is a LHT.
As I said above, the dealer told me that there nothing wrong with the "wrong" nut, it's just that it may not have been tightened to spec when assembled.
Old 12-09-2019, 01:13 PM
Rodent, you really made my day. Thank you so much! It makes it easier for me. I will check this tomorrow with a strong flashlight. Yep, if its black or silver with cuts its okay.
I'll report back!
Thanks again !!!
Doc
Old 12-10-2019, 12:06 AM
shawbagga's Avatar
I believe it was excessive clearance on threads making them not tighten correctly/loosen easily also.
'18 Gasgas XC250
Old 12-10-2019, 01:05 AM
rodent's Avatar
Do you know that 1st hand? Guy who did mine told me they were the same.
I never had both nuts in my hand at once(well you know what I mean) so I cannot confirm, but I have known this guy for many years and I am confident that he not mistaken.
If someone has both I'd love to hear their opinion.
KYB technical touch USA website GG221 Enduro Suspension 0 06-14-2019 08:03 PM
Post your hard technical trails here hawaiidirtrider Pictures & Videos 29 05-11-2013 12:07 AM
Please use the Technical Forums for specific questions MattR General Discussions & Announcements 1 01-14-2008 07:24 PM
Website/bulletin board downtime possible. webmaster General Discussions & Announcements 0 12-14-2006 03:56 PM
Bulletin Board Upgrade... webmaster General Discussions & Announcements 0 08-27-2006 09:46 PM
