Old 12-08-2019, 07:33 PM
GG221 GG221 is offline
Default Bike overheating
My bike is overheating easily. Radiator will be smoking after even a mellow hill climb. I let the bike cool down and check the radiator is full, but I can see a thin film of what I think might be oil on top, but not positive. It is not very milky like heavily contaminated oil, but maybe there is a small amount. When I change my transmission oil it does not look very milky at all.
Any ideas?
2018 XC 300
Old 12-08-2019, 08:28 PM
Any ideas?
2018 XC 300
Your water pump shaft seal may be leaking. Pull the impeller off and inspect the seal and shaft
Old 12-08-2019, 09:33 PM
I will check that out. Would that cause overheating?
Old 12-08-2019, 11:10 PM
Is the pump working?
Old 12-09-2019, 09:44 AM
No, that would not cause overheating. Very often the culprit is the rad cap or better the over pressure valve in it. Could also be a lose impeller.
Old 12-09-2019, 03:55 PM
Laszlo ervin Laszlo ervin is offline
Do you have a fan?doaes not start? Chech the radiators if its clogged or something..
Old 12-09-2019, 08:26 PM
Today I looked in the radiator and it looks dry. I added about 1 cup of coolant and it was full again started the bike and I can see that the pump is working. It looks to me like the steam or smoke is coming off the header pipe. Maybe it is just a leak somewhere?
Old 12-09-2019, 08:57 PM
is this a new issue? or is it a new bike? If it is a new bike it could be jetted too lean.
Old 12-09-2019, 09:08 PM
It is a new issue. I think jetting is good.
Sounds to me like i should replace the head o-rings and the water pump shaft seal.
Any other parts I need to order along with the pump shaft seal?
Old 12-10-2019, 01:19 AM
If the gear oil is not milky then pump seal should be fine. If you do have to replace the seal check the shaft. Mine got a groove in it. Was quite cheap.
I have a bung with a shrader (tyre) valve in it. You could glue one into a piece of plastic or drill and tap. This bung is radiator hose size. Put a plain bung in other hose and put a radiator in a bucket of water and a couple pumps with a bicycle pump. You'll quickly find a leak or prove it as a good part.
If they both prove fine and you swap a cap over then yeah I'd replace the head o-rings.
Overheating problems CombatYoga Enduro Engine - 2 stroke 6 08-16-2015 05:16 PM
Overheating Ec300 normanator27 Enduro Engine - 2 stroke 37 03-01-2015 09:29 PM
03 ec300 overheating waycrazy Enduro Engine - 2 stroke 16 08-10-2012 12:13 PM
Ec 250 Overheating New Piston? Elliker Enduro Engine - 2 stroke 6 07-16-2009 04:55 PM
A few questions (overheating) 2 strokes 4 life Enduro Engine - 2 stroke 8 06-03-2008 09:13 AM
