Old 02-20-2020, 07:16 AM
emepher emepher is offline
Default HELP: 2018 GGEC300 Removing starter area conical gear and bearings
Recently found my bearing seized and the conical gears are not spinning. I sprayed penetrant and unseized the bearing but want to replace it. In what order are they removed and how?
Old 02-20-2020, 07:37 AM
Nocams Nocams is offline
I used heat on the starter casting and a few firm taps on the edge of the workbench.
Came out nicely.
2011 TXT300R
2018 EC300GP
Old 02-20-2020, 03:32 PM
yep, heat around the outside of the case where the bearing lives.
I also made a tool to fit behind the pinion section of the shaft that fitted onto a slide hammer. This helped.
Old 03-03-2020, 08:28 AM
eralha eralha is offline
Hi, is your shaft welded to the gear? Was it come this way or did you do it after?
Thanks.
Old 03-20-2020, 05:32 AM
JoseGas25's Avatar
JoseGas25 JoseGas25 is offline
Hello, I used this "tool". Nut and screw. I removed also the gear that is fixed with the axis but i don?t know how to explain in english, sorry.
400fse-450fse Starter gear and one way clutch mod krolik_21 Enduro Engine 4 stroke (including EFI & Exhaust) 5 08-22-2019 05:58 PM
2013 XC300R-E starter gear rosco "Wanted to Buy" & "Want To Trade" 2 04-11-2019 08:36 PM
Kick starter gear with zip ties CanGasser Enduro Engine - 2 stroke 4 01-07-2017 03:48 PM
2012 starter gear how much !!!!! Watty Enduro Electrical & Wiring 4 11-22-2014 01:43 PM
Starter clutch / gear problem iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 12 01-28-2011 02:45 PM
