Clutch free play
Hi all. So recently installed a new clutch kit on the bike. She's running lovely now. But after some hard technical climbs where the clutch is being used to moderate power output the free play in the clutch lever increases drastically sometimes even into the bar. After about a minute it goes back to normal. Any ideas anyone? Thanks
Sounds like air in the clutch hose.
Probably needs to be blead. |
I thought that so I took the top cap off. Removed the slave cylinder from the bike. Pushed the piston out and back in a few times. And no air rose to the top. I will try a full bleed tho
Thread Tools | |
Display Modes | |
2001 ec300 power valve free play | krazy | Enduro Engine - 2 stroke | 1 | 09-26-2015 04:26 AM |
Throttle free play | 95jersey | Enduro Chassis & Body | 6 | 06-25-2015 05:07 PM |
Slight free play in forks | 400_racer | Enduro Suspension | 9 | 06-27-2012 09:38 AM |
Free Play in Sachs Forks? | 2whlrcr | Enduro Suspension | 10 | 03-07-2011 10:45 PM |
2011 ec 300 Throttle Cable doesn't have any free play... | rgranger | General Discussions & Announcements | 7 | 01-29-2011 10:03 PM |
