Old 05-28-2020, 10:33 PM
Dougie Dangerous Dougie Dangerous is offline
Default Power Valve Adjustment issue
Removed cover plug from power valve adjuster and found this....
Looks all wrong to me , not like pictures in manual or u tube. Whole assembly seems to be sticking too far out and you can see a large clip at the rear of the shaft which I cant see in any pictures ....
.....any ideas what has gone wrong.... HELP!
Old 05-28-2020, 10:38 PM
Look on pg25. Looks OK.
https://www.dropbox.com/s/i93vw77r9k...anual.pdf?dl=0
Old 05-28-2020, 11:45 PM
Attachment 8673
Attachment 8674
Attachment 8675
Attachment 8676
I think you are missing the outer bearing.
Old 05-29-2020, 03:59 AM
I think so too, page 43 shows the bearing in the cover, i'd be pulling it off and inspecting. I think you will find the bearings at the bottom of the motor with what is left of the cage.
Old 05-29-2020, 04:57 AM
eralha eralha is offline
Attachment 8673
Attachment 8674
Attachment 8675
Attachment 8676
As others have said you are missing the bearing, it seems that the inner race of the bearing is still on the shaft, if i was i your position i would take the right cover out and check if it is on the bottom of the case.
Old 05-29-2020, 06:45 AM
Thanks for the replies....any idea what could have caused this to happen?
Old 06-01-2020, 02:42 AM
Originally Posted by eralha View Post
... it seems that the inner race of the bearing is still on the shaft...
I don't think so, I just checked a picture I made when I had the inner cover off to replace the crank nut and it seems there is a bushing between the clip and the lock nut. Its not part of the bearing.
They have just forgotten to install the bearing I reckon...
Old 06-01-2020, 11:41 AM
Thanks Doc!
Old 06-10-2020, 06:14 AM
Latest instalment - took the bike to the dealer ...they found the bearing inside the cap
Said ..."The bearing sits inside the screw out cap and slides over the shaft as the cap is located and screwed in. ".... I guess that makes sense if you look at the diagram on page 32..if its part number 39.
You wouldn't be able to see the bearing that is pressed into the back side of the cover ..part number 12?
What do you think?
Old 06-10-2020, 07:51 AM
Attachment 8685
What do you think?
The bearing should be pressed into the case. It does not come out with the cap on my bike or in any of the pictures I have seen
Gasgas EC 300 2018 power valve adjustment eralha Enduro Engine - 2 stroke 13 04-29-2019 03:42 PM
2018 XC 300 Power Valve adjustment Islander Enduro Engine - 2 stroke 3 07-11-2018 09:44 AM
Power valve adjustment on 15 engine Adam500 Enduro Engine - 2 stroke 3 03-24-2017 07:14 PM
ec125 -01 power valve issue? Nicolas89 Enduro Engine - 2 stroke 83 08-06-2014 04:33 AM
Power Valve Adjustment Skele Enduro Engine - 2 stroke 2 08-17-2009 08:31 AM
