Sachs shock bearing
Hello everybody i own a 2009 ec 250 base model with a sachs rear shock , when i move the swingarm by hand i can feel a bit of play by the top shock mount , so i thought i should change the top shock bearing .
The thing is gas gas does not sell this part neither does any after market company i searched for . Did any of you have this problem solved ? Does anybody know the dimensions of the bearing so if i can find one from a bearing company like skf ? |
Did you contact RaceTech?
Not Sure if any help, but lower shock bearing on my 2013 = GE12-PW
No i looked everywhere in my country (Greece) i will look them up too .
Thanks for replying . |
Pivot works has the bottom bearing listed i think so i dont think they are the same .
So replacement bearing arrived and i removed the shock to find that the bearing was ok but the two spacers which the bolt goes through had too much clearance so i need these two spacers replaced .
I removed them using a punch and a small hummer and because of the deformation by the punch the bolt now fits tight , so i packed the bearing with grease and pressed the spacers in and fitted the shock back i had to tap the bolt with a hummer to get it through the shock . I will see if this last until i find the spacers and replace them . |
GasGas EC250 2009
Can you tell me how i can find the Upper shock bearing kit? |
So i am waiting once again for parts to arrive . Sorry for the late reply , here is a link to the bearing kit. https://www.enduropuro.it/shop/en/li...gas-01-13.html |
So uniball kit arrived , its WRP part number WY -29-5080 , kit includes bearing , spacers ,orings and circlips .
Just tried the shock bolt through the spacers and there is some gap !!! Do i have to change the shock bolt too ? Is it ok to have some gap ? I find it annoying when i lift the rear wheel and set it down to hear the suspension knock . This is pissing me off now . Anybody has any ideas ? |
it depends on how much gap there is. measure the hole and measure the bolt. I believe it is normally the bushes and bearings that deform and the bolts stay good.
If the bolt is still good then just pack it witha bit of grease and when you tighten it, it could be fine
Sachs top bearing removal | 5valve | Enduro Suspension | 7 | 07-12-2022 03:58 PM |
2018 KYB shock bearing | eralha | Enduro Suspension | 9 | 10-31-2019 04:10 PM |
Lower bearing replacement in Sachs rear shock | Blambo | Other GasGas Bikes/Quads | 1 | 04-02-2018 12:51 PM |
ohlins shock bearing | imsimon | Enduro Suspension | 7 | 12-12-2017 03:55 PM |
rear shock bearing | gassergrant | Enduro Suspension | 0 | 12-13-2014 11:33 AM |
