Hello to everything. While I was working on my gas pampera 400 gas, I was closing the flywheel crankcase and I accidentally broke the ignition coil.
I can't find the original spare part. Does anyone know if I can adapt The Ignition Coil from another similar bike? |
Generally people call the frame mounted ht coil the ignition coil. The stator contains the ignition charge coil. But I suspect that you are talking about the small plastic case which in English has several names. Pick up coil. Sender coil. Pulsar coil, and probably others. Then of course the Spanish ones.
Fortunately all they do is pick up a small charge as the flywheel goes past that tells the ignition to fire. The good news is that it should be easy enough to find a similar coil. If like the Enduro 2 strokes the run kokoshin electrics, ktm use them. Probably not as a single part, but a burnt out stator loom would have one. Found these separately but you'd have to confirm size and mounting position. https://www.ducati-kaemna.com/catalo...tore=tuning_en
A Suzuki DRZ coil may fit.
Tags |
ignition, pampera/fse, replace |
Ignition coil | Gassedshaun | Enduro Electrical & Wiring | 0 | 12-24-2017 04:35 AM |
2005 (maybe other years) ignition coil | Vinny | Parts | 0 | 09-21-2016 11:58 AM |
Ignition coil | davedunaway | General Discussions & Announcements | 2 | 09-04-2012 12:22 PM |
Any options to replace ignition switch on 2011 300? | rgranger | General Discussions & Announcements | 13 | 02-19-2011 06:58 PM |
