Old 12-13-2008, 10:34 PM
Grampy Grampy is offline
Question EC 250 Spark plug
The manual that came with my Gas Gas 250EC calls for a NGK BR8EG which is a resistor plug. The NGK book at my dealership calls for a B8EG non resistor plug. Any problem with running a non resistor plug? Have heard concerns about non resistor plugs harming CDI units.
Thanks
Old 12-13-2008, 11:50 PM
widebear's Avatar
widebear widebear is offline
Banned
Just put in a resistor plug. Their main purpose is to cut down on rf noise that can interfere with radio and other forms of communication and sensitive electronic transmissions and data aquasision.
Old 12-14-2008, 11:02 AM
MattR's Avatar
MattR MattR is offline
Like widebear mentioned, use a resistor plug. I have used both BR8EG and BR8ES plugs. The G plug has a fine wire nickel alloy electrode, the S plug has a standard 2.5mm electrode.
Matt
Current: 2009 Yamaha FZ1
Old 12-14-2008, 02:57 PM
Which worked better, the BR8EG or the BR8ES?
Old 12-14-2008, 03:10 PM
roostafish's Avatar
I fouled a plug once at high elevation and put in a B8ES which I had as a spare. I forgot about it, and ran it for about a year before I did the squish band mod on my head and found it. I laughed at myself as I took it out.
My experience is that it doesn't matter a bit which plug you run. The expensive electrode is a waste of money. I would still choose a resistor just in case there were interference issues, but I certainly didn't have any with the non resistor plug.
Mike Sheetz
OMRA #21AA
'15 KTM 300 XC-W
Gran Prix Cycle
LTR Suspension
RB-Designs
Old 12-14-2008, 05:45 PM
MattR's Avatar
I had same results as roostafish. I could not tell a difference between EG vs. ES. It probably depends on how well your jetting is dialed-in. I found BR8ES easier to find so I just run those in my bike.
FYI... there is also an iridium plug that may be interesting to try out. In my Husky SM610, this plug is a well known trick to eliminating some rich hesistation at 4000 rpms. The iridium plugs are pricey at $10 each. The iridium plugs provide a stronger, more consistent spark for a cleaner burn.
Here is more info:
http://www.ngksparkplugs.com/product...x.asp?mode=nml
I usually replace my spark plug yearly for piece of mind. So I will probably throw one of the iridium plugs in to try out. The GasGas EC250 would use a BR8EIX iridium plug (where IX is the callout instead of EG or ES).
Matt
Old 12-14-2008, 06:31 PM
2 strokes 4 life's Avatar
I highly recomend a BR8EIX. Its a great pulg and wont foul. I was running a 185M jet, 48 pilot, and AS 1 turn out durring break in and then swapped out to a 175M, 42 pilot, and 1.5 turns out. Saying the least I was running rich and it still never fouled. Best under $10 spent ever.
2012 Ktm 300xc
2001 Gasgas EC300
Old 12-14-2008, 08:44 PM
jostby jostby is offline
Do yourself a favor and drop the "R" resistor plug. I did on both my bikes and have never been happier. No cdi interferance. The resistor is designed to "resist", ie: more current to make a spark and at the same time also reduces radio interferance which can affect some electronic ignitions and especially transmitted frequencies (am/fm/television). If everything is working fine that's great, actually it's excellent. If you get to the point it is taking too much current (running rich from a tipover or a long downhill on a cold day) it can burn out the resistor.
'00 XC250 (mine)
'04 EC250 (the kids)
Old 12-15-2008, 07:11 AM
joey11 joey11 is offline
I've ran both ES and EG plugs, but now that I run an ICO, I've been using the one with a resistor. Should I not worry about that and run a B8es? Will the computer be OK?
Old 12-15-2008, 08:58 AM
Skidad's Avatar
Skidad Skidad is offline
+3 on the Iridium plug.
I've used them for years on my KTM and will also use one on my new to me 07 EC300. Never fouled one and I believe it helps the bike start easier. Change it out once a year for piece of mind.
97 KTM 250 EXC (sold)
2016 Trek Remedy 29er
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
spark plug wear mountain thumper Enduro Electrical & Wiring 1 05-17-2009 10:12 AM
01 ec300 spark plug.... jhendr3702 Enduro Electrical & Wiring 1 07-02-2008 07:53 PM
Spark plug gap???? Bandit9 Enduro Engine - 2 stroke 1 08-29-2007 05:26 PM
