Old 02-09-2009, 02:01 PM
ferguscawley ferguscawley is offline
Default Tuning Question - Sachs 09 Forks
I have a question for the suspension tuners among you .
I am the gasGas distributor for Ireland and having owned a few EC300s with both marzocchi and sachs forks, I want to make the sachs forks behave like the older 45mm Marzocchi shivers if possible. I find the sachs to be hard work over rocky rutted terrain that is common on Irish trails.
I have tried a few changes on the sachs forks - just playing with clickers, oil weight and airgaps but still can't get that lovely controlled feeling I had with my 06.
Here is the valving arrangement for the compression piston for the 2T enduro bikes.
What shim sizes / order should I use to get the same plushness that I got from the Marzocchis on my older 2006 bike ?
Any advice or help would be much appreciated.
Many thanks
Fergus
Old 02-09-2009, 03:22 PM
Correct me if I am wrong but if I removed 3 shims from the stack to give me the stack below, would I not have a more supple compliant ride over rocks and ruts/roots etc ?
I am trying to figure out the workings of the compression stack using various forums and titbits of info I can find.
23 x .2
24 x .2 (removed a 24 x .2 shim here)
16 x .15
20 x .15
18 x .2 (removed a 16 x .2 here)
12 x .12
10 x .3
22 x .45
22 x .45 (removed a 22.45 here)
20 x .1
16 x .3
I am also assuming that the red shims above are the low speed stack, the blue shims relate to the mid speed stack and the pink shims relate to the high speed stack ?
Thanks
Fergus
Old 04-16-2009, 06:43 AM
add add is offline
Any luck on the valving? I found my Sachs to be pretty stiff too.
Old 05-25-2009, 06:01 PM
Keg Keg is offline
Here is what is in my 300R forks.
Compression
3mm bypass hole
26(D) x .15 (5)
24 x .2
12 x .15
22 x .2
20 x .2
18 x .15
16 x .15
12 x .15
10 x .3
Rebound
Check Valve 26mm
2.5mm clearance/height
3.5mm bypass hole
24(D) x .1 (3) ****this does not fully cover the valve body holes
22 x .15
20 x .15
16 x .15
12 x .15
10 x .3
Old 06-14-2009, 02:39 PM
Transparent tank's Avatar
Transparent tank Transparent tank is offline
+1
ferguscawley, how does your stack work over rocks and roots?
2011 EC250 Cervantes Replica
Old 06-14-2009, 03:35 PM
Originally Posted by Transparent tank View Post
+1
It was much improved over stock. Forks were iniitially much plusher but I still felt that I couldn't trust the front end over roots etc - sometimes it would deflect without warning and other times it wouldn't.
I think the forks are also over-sprung for enduro use which doesn't help much either.
I have since sold my front end and fitted a set of 2008 marzocchi forks & clamps to my 09 bike. Much much better for the Irish terrain.
Old 06-15-2009, 12:41 PM
Well i´m about to try this stack
23 x .2
24 x .2
16 x .2
20 x .2
18 x .2
12 x .15
10 x .3
22 x .45
22 x .45
20 x .10
16 x .3
Along with 110mm airgap, but i really dont have a clue what i´m doing (as always).
Old 07-15-2009, 07:12 PM
Keg Keg is offline
I have recently had the check plate on the back of the rebound valve converted to a mid-valve by Dirtworks Suspension in Australia. It took a bit of machining and a few re-valves, but it is now miles better than before with a plush feel, but much more planted mid turn and on handles the bigger hits!
And I can survive a whole cross country race now!
Old 07-15-2009, 09:23 PM
Those heavy 3 stage stacks never seem to work well in the woods. My Cannondale Ohlins had something like that and the bike was unridable. Best to go to a more conventional 2 stage stack. It appears that stack also uses a 23mm face shim for free bleed. Also, if there is a lot of free bleed in the rebound, perhaps rebound control is an issue as well.
Old 06-28-2010, 01:58 AM
bergerhag's Avatar
Anyone got a good woods/rocks stack that they can share? My 2010 ec300 fork does not work at all for the terrain I ride. Guess it is time to redo all the work I put into my zokes...
2009 SACHS Shock Question 300XCRider Enduro Suspension 4 02-16-2011 07:59 PM
Website tuning.... webmaster General Discussions & Announcements 17 10-09-2010 12:13 PM
2010 sachs forks bowtech Enduro Product Announcements 13 09-09-2010 07:50 AM
Sachs forks steve Enduro Suspension 1 11-07-2008 06:03 AM
GasGas sm 125 tuning EmilO Enduro Engine - 2 stroke 0 08-14-2007 05:18 PM
