Old 06-05-2009, 12:28 AM
lineman12345678 lineman12345678 is offline
Default washers on lower rear shock?
I pulled my suspension off to have it re-valved and serviced by Les at LTR. My question is. On the lower part of the rear shock mount which way do the dished washers face. I was thinking it is with the cup side toward the barrings is this correct?
Old 06-05-2009, 05:05 AM
eff's Avatar
eff eff is offline
They go like this (|)
2004 GasGas DE250
Old 06-05-2009, 05:46 AM
MattR's Avatar
MattR MattR is offline
Lineman, you are correct.
For future reference to other users...
Here is a pic that I made previously. It's rough, but gets the point across. I like Eff's idea too but it looks like a butt. Dirty mind I guess.
Matt
Current: 2009 Yamaha FZ1
Old 06-05-2009, 08:07 AM
blitz11's Avatar
blitz11 blitz11 is offline
You're worried about that looking like a butt with that avatar?
i actually saw that "A Style" sticker for the first time in the train station in Torino, Italy, in 2007. Rather amusing.
blitz
Old 06-05-2009, 10:26 AM
So what is the secret to geting them back in easy. I can get one side but not the other.
Old 06-05-2009, 11:21 AM
eff's Avatar
eff eff is offline
LMAO! No doubt you are the master of posting technical drawings! I thought it looked like a butt too, but hoped it got the point across.
2004 GasGas DE250
Old 06-05-2009, 06:49 PM
MattR's Avatar
{Speaking in broken chinglish} Young grasshopper... there is much to learn. You must have patience to yield the cupped washers into final resting place. Use three hands to hold the cupped washers, while squeezing them together slightly, and gently slide the clevis into place.
When that zen moment fails, I try to hold the cupped washers in position and "wiggle" the clevis onto the washer's edge. If you're lucky, you can compress the washers as you slide the clevis into position. It's still a pain for me too.
Matt
Old 06-05-2009, 11:40 PM
It does just take a bit of patience but i did prevail
Old 06-01-2014, 09:28 AM
kyton's Avatar
kyton kyton is offline
I got another shock with a clevis that is not broken and tried to put it on with new orings as washers. I cant seem to get them on. shock goes on with either the orings or washers only in place.
Old 06-01-2014, 09:40 AM
djroggen's Avatar
djroggen djroggen is offline
The orings should seat somewhat inside the rear pivot, and the washers should go right over with little compression to make them fit, you may have a set of orings inside the pivot already?
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Rear Shock Spring--Where Am I? Where Do I Go? smstewart Enduro Suspension 0 04-19-2010 05:35 PM
Removing Rear Shock gasIdaho Enduro Suspension 12 02-04-2009 10:45 AM
Rear linkage brackets lower mount 3hunerd Enduro Suspension 2 10-16-2008 09:42 AM
lower shock bearing cross-ref? fasternat Enduro Suspension 1 02-21-2007 10:20 AM
Lower rear suspension-also tailight holder mattmax General Discussions & Announcements 2 11-11-2006 08:51 AM
