Old 01-23-2008, 09:54 AM
widebear's Avatar
widebear widebear is offline
Banned
I have to agree with Glenn on the point of balance. .47 are super heavy springs. To generalize I'd say .47's are for 250 plus pound riders and a 5.2 rear for a 170 lb or less rider. you all so need to add alot more rebound damping on the forks to offset the extra energy that will be stored in the spring on compression. You must be running very little oil in the fork in order to get full travel? What do you weight with full gear on?
Old 01-23-2008, 10:23 AM
cladoo's Avatar
cladoo cladoo is offline
Never weighed myself with full gear on but I weigh 215lbs. with my gym clothes on. The springs are actually .46 that I got from LTR.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Old 01-23-2008, 02:40 PM
widebear's Avatar
Banned
OK those are not unreasonable spring rates for the forks, givin your weight. but i can assure you that a 5.2 rear is to light for your weight. 5.5 to 5.6 would be more in the ballpark, and then and only then can you follow Glenns sound recomendations for sag adjustment.
Old 05-19-2008, 12:18 PM
GG27 GG27 is offline
Default EC 2008 settings
After riding my EC 250 for 4 months on all sorts of terrain I have come up with the following settings(BTW I'm 190 Lbs):
Mazorcci 45's : Compression Damping 21 out
Rebound 6 out
Forks raised 5 mm up
Sachs LS comp 1 3/8 out
HS comp 20 out
RB 20 out
Static Sag 32 mm
Race Sag 110-112mm
What is the standard settings for the 2008 models since the manual doesn't have them?
EC250 2008 Skid plate, rad braces, Fork bleeders
Drz 400 Motard '03 (full spec)
Yz 250 '06, KTM exc 250 '05, exc 250 '04, exc 250 '02
WRF250 '02, KDX 220 '98, DT200R '93 all sold
Old 06-22-2008, 12:45 PM
darren's Avatar
darren darren is offline
I have a 1999 EC250 You talk about rebound and compression. on my front forks there is a blue knob at the top. On the bottom of the forkleg there is no other adjusting screws. Does the top adjuster just set one or both of the rebound or compression??
Old 06-23-2008, 06:32 AM
Leon_gasgas Leon_gasgas is offline
As I remember, left knob is for the compression and right for the rebound. 8 clicks out for either is the standard setting.
Old 10-07-2008, 03:55 PM
darren's Avatar
I have a 1998 EC250 Does anybody have the stock settings for the rear ohlins on this year bike.
Also i set the preload on the rear spring to 8mm on checking the static sag it measured up at 40 mm.
the spring has some numbers on it but they dont mean a lot to me.
The numbers are 596-09/05 088 I weigh about 170 lbs
If i wind down the preload to get 15mm static sag then the spring ends up 3/4 way down the thread well under the thread center line.
Any body help?
Old 06-26-2009, 08:42 PM
spdfrek spdfrek is offline
Does the low speed have to be re-adjusted on the ohlins after moving the high speed, or just the sachs?
Old 09-27-2009, 10:05 AM
GasGasser GasGasser is offline
Does anybody know the stock / the best settings for a 2003 EC 300? It has got the Marzocchi fork an the Öhlins damper.
Old 09-29-2009, 06:16 AM
Anyone? Which are the standard clicker settings? I can't find out from the manual.
Gas Gas EC 300 09 Basic Suspension Settings snaissidis Enduro Suspension 0 03-16-2009 04:05 PM
2005 baseline settings stay_upright Enduro Suspension 0 01-26-2009 08:37 AM
450 fork settings? splint Enduro Suspension 0 10-14-2008 03:30 AM
baseline ohlins setting fullthrottle Enduro Suspension 5 04-26-2008 08:15 AM
EC300 Baseline settings Magellan Enduro Suspension 7 08-26-2006 06:30 AM
