Old 07-13-2009, 08:27 PM
noobi's Avatar
noobi noobi is offline
Default hot start extreme difficulty
my 07 ec125, has just had a new piston and rings. and now its become very difficult to start hot. i have to put the choke on and open the throttle to WOT and kick it really hard to get any sign of life out of it.
it wasnt this hard before the new piston.
everything was fine when i did the rebuild, no bore scratches or wiggle in bottom end.
one of my bike mates suggested it could be the jetting, i dont know
its a 40 pilot jet, a 175 main jet with a N1EG on the 2nd position, air screw 3 turns out
any help would be appreciated
Old 07-13-2009, 11:17 PM
widebear's Avatar
widebear widebear is offline
Banned
Air screw adjustment is to lean , try 1 turn out.
Old 07-14-2009, 12:27 AM
noobi's Avatar
ok, thanks
the bike shop commented on how it was happier with the air screw 5 turns out and suggested a biger pilot. does that make sense with what your saying?
Old 07-14-2009, 04:17 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by noobi View Post
ok, thanks
5 turns out! It must be nearly falling out
If you need 5 turns out I think it suggests you need a smaller pilot. Turning it out leans the mixture. It's easy to adjust so if I was you I'd put it back to standard ride the bike and see how it behaves. You'll probably need to adjust the throttle stop to get an idle if it's setup 5 turns out.
Old 07-14-2009, 05:45 AM
noobi's Avatar
dunno really. ill play around with the air screw tomorrow, school holidays are great for playing with bikes, and see if i can sort it out. but the report i got from the shop definately says bigger pilot
Old 07-14-2009, 06:55 AM
Five turns out is crazy. There is something very wrong to make it run better like that. How does it run otherwise, is it OK once your off the idle/pilot circuit? Did the carb come apart for some reason?
Old 07-14-2009, 10:57 AM
rpduc rpduc is offline
If the shop is saying bigger pilot AND screwing the air screw out they've got some wires crossed...
That could have been a brain fart on someone's part.
Put in the bigger pilot they suggested and start at 1 turn out and see what you get.
By 2nd position I assume you mean second from the bottom? Because second from the top would also lean it out.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 07-14-2009, 04:28 PM
noobi's Avatar
no, 2nd clip from the top!?!?
the bike runs very well on and off the pilot circuitry, its just hard to start, and it wasnt like that before the new piston, it doesnt exactly rip my arms off, but its a 125 not a 450. there are no flat spots to speak off and revs up cleanly. but i dont know the difference between a well jetted bike and a poorly jetted bike. it runs and its smooth
Old 07-14-2009, 05:25 PM
widebear's Avatar
Banned
Noobi.rpduc's advice is correct. The air screw's adjustment range is only 0 to approx 2.5 turns out. Half to one and a half turns out being the sweet spot. Anything either side of those parrameters will require a pilot jet change.
Old 07-14-2009, 05:32 PM
noobi's Avatar
ok, ill invest in some pilot jets. 42?
VORC Extreme Sprint -Australia Keg Ride Reports 0 09-12-2010 07:35 PM
Canada's first Extreme Enduro: Xtinction SpeedyManiac Pictures & Videos 6 08-29-2010 05:55 AM
Enduro Extreme Genova 18-02-2007 gasgasman Pictures & Videos 1 04-02-2007 09:04 AM
extreme heat? crazjarhead Enduro Engine - 2 stroke 6 08-24-2006 08:03 AM
Hancock WEC Extreme Test Helmet Cam Videos Berkyboy Pictures & Videos 3 08-03-2006 01:33 PM
