Old 01-14-2010, 11:44 PM
lordfeyr lordfeyr is offline
Default CRD radiator guards
Anyone running these?
If you could take a pic of how these are mounted it would be much appreciated. I picked these up used and have no idea on how to mount them on my 04 300.
Old 01-15-2010, 11:50 AM
Krasi's Avatar
Krasi Krasi is offline
I have a set for 08, mounted on a 09 model. Had to manufacture additional bracket, because the ignition coil was in the way.
Instalaltion is pretty easy - there are two tubes that are mounted in front of the radiators, and brackets that are tightened on the frame under the tank. Right and left guards are different!
Old 01-15-2010, 12:09 PM
Thanks I actually just finished putting them on.
The right side one actually came with a longer bolt to go through the ignition coil right side hole. The left side had a rectangular brack that went around the frame under the gas tank.
Pretty easy once I broke down and started looking at it.
Old 01-18-2010, 08:23 AM
Triple W Triple W is offline
I've got them on my 04 250. They do the job. TW
Old 01-18-2010, 08:24 AM
Anyone know if CRD guards are avalible for newer bikes in the U.S. ? Thanks, TW
Radiator Guards? Boomhauer General Discussions & Announcements 4 08-24-2007 08:42 PM
CRD radiator guards Loosenut Enduro Product Reviews 20 06-06-2007 02:15 PM
