EC 400 is the battery dead
My EC400 was starting fine until a couple of days ago. All the updates are fitted, so it's not down to that. When I switch the key on, the injector doesn't prime itself, n'or does the fuel pump kick in. The battery is reading 13.5V, same reading at all the fuses. That's as far as I've got, any advice is more than appreciated (won't bump start either)
Does it turn over? If so maybe the fuel pump relay is giving you fits? Do a search. There has been a lot of threads on this subject.
It turns over fine, the battery appears to be fine, giving plenty of revs before the charge gives up. I'll look into the fuel pump relay issue. Thank you |
Spoke to the dealer who supplied the bike, who told me to swap the relay for the starter over with the fuel pump relay (both the same, located behind the lhs side panel). All will be revealed hopefully
Hmmmmmmmm, there's only one relay! Still Youtube is very helpful in respect of testing
The same relay can be had from Fiat dealers at half the price of GG dealers, use the long number on the side (Fiat have used this as thier part number)
Replaced the relay and still nothing. The fuel pump is fine as I've bridged it from the battery and it runs ok. Bridged the "diode" fuse and the soliniod responds ok WTF TIA
Mine behaved a bit like that and refused to work again until it was plugged into to the diag machine and all the errors cleared and reset, a cheap fix - were the dealer not 100 miles away!
Racing start - dead engine tips please | stay_upright | Enduro Engine - 2 stroke | 12 | 04-19-2011 04:47 AM |
Dead 02 EC 200 | markwoodlief | Enduro Engine - 2 stroke | 21 | 02-19-2011 03:56 PM |
100% Tariff dead | gasgasman | General Discussions & Announcements | 3 | 01-17-2009 05:54 PM |
Battery Blues | andye | General Discussions & Announcements | 0 | 05-24-2008 09:17 AM |
Dead spot in throttle | west aussie gas 450 | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 01-29-2007 03:51 PM |
