Cross-over parts help
Hey Guys,
I'm in the process of freshening up my bike for the upcoming race season. Two parts I definitely need to fix are the rear brake pedal (tip is severely cracked) and the countershaft sprocket. I got price quotes (Canadian dollars) of $160 for the brake pedal and $50 a 13 tooth sprocket which I think is pretty high. What is the modification to fit a rear brake pedal from a KX (which year/model pedal too) and is there any countershaft sprockets that cross-over? I'm also thinking about replacing the plastic (rear fender is toast, shrouds are cracked, same with side panels and headlight cover) but the OEM stuff is pricey. Is there any aftermarket or crossover stuff available? Thanks, Steve P.S. My bike is a 2001 GasGas EC200. |
Only sprocket that crosses over is a TM, which saves you nothing. Get an Ironman CS, they last much longer than the Talon.
As far as the pedal I also heard a KDX pedal can be modified to fit, but I nevr tried it. Its steel so it should be easier to work with. You could also just TIG up the crack and ears, and remachine it to fit a new tip, or a non-folding Husky tip. I thought the plastic was reasonable. Are you sure your prices are for the '01 plastic, as the '02 stuff was clearcoated and a lot more $$. '94 - '98 KX250 rear plastic is said to fit with some mods but I never tried it. |
The parts guy gave me the part #'s and they're the same as in my parts fiche for an 01 EC200. I asked him if they include graphics or something because they seem rediculously high ($80 for the rear fender, $115 for each shroud, $60 each for side number plates).
I have a spare brake pedal I can send your way - check your PMs. jeff |
PM sent. I can't believe some of the GasGas prices. Usually they're so good!
Try Ebay for the plastic. Search gas-gas in ebay stores.
Speedy, the prices you were quoted were including graphics. If you order the plain, non-graphic version they are very inexpensive, even compared with aftermarket.
I just sold a new leftside rad shroud for an '06 with graphics for $76.95CDN . I am not sure where you got prices from.
Claude 2019 XC300 2010 Nambotin 300 sold '07 EC300 sold '06 EC300 sold '78 Suzuki RM250C2 '75 Yamaha YZ250B sold |
I have switched a KX125 (early 90's) rear break on my 2004 EC200
My dealer said he can only get me the plastics with graphics which is why the prices were so high. Seems weird that every other GasGas dealer in the country can get the plastics without graphics but they can't.
reeds cross-over? | moff747 | Enduro Intake/Carburetion - 2 stroke | 4 | 05-25-2010 02:32 AM |
crankshaft cross-over | whodat | Enduro Engine - 2 stroke | 2 | 04-26-2010 06:05 AM |
Is there any cross over parts for throttle cables for an 03 ec 250? | dank | Enduro Product Reviews | 5 | 04-12-2010 08:51 AM |
How do we add to the cross over list? | brains | General Discussions & Announcements | 1 | 07-26-2007 03:11 PM |
Bearing kit cross??? | Dingoe | Enduro Suspension | 4 | 12-14-2006 10:23 PM |
