Old 04-22-2010, 01:40 AM
ggg ggg is offline
Default FSR 450 valve check and timing chain
Hi i am about to check my valve clearances for the first time, the bikes done10,000ks and its not starting as well or idling as sweet during warm up.
I have read the great valve check guide on Thumpertalk for a DRZ 400, and from what i have been told the top end is the same, so i can use that as a procedure to check and replace shims if i need to.
My question is when i am doing the valve check how do i tell if the cam chain requires replacement, is it simalar to checking a regular chain by pulling on it and see how far it rises up on the cam sprockets? i would presume that would be the time to check it, anyone go any suggestions? i have both Gas gas service manuals they just show the removal/ install, thats about it.
450 Fse Valve Train and Timing twowheels Enduro Engine 4 stroke (including EFI & Exhaust) 4 09-23-2010 06:36 AM
Marzocchi 45mm mid valve check plate stay_upright Enduro Suspension 10 04-02-2010 12:37 AM
fse 400 valve timing ??????? mcludd Enduro Engine 4 stroke (including EFI & Exhaust) 4 08-29-2009 11:54 AM
HELP How do I check and alter timing? wence Enduro Electrical & Wiring 3 05-09-2009 04:28 PM
How do I check port timing? moff747 Enduro Engine - 2 stroke 1 04-08-2009 05:27 PM
